Old 26th Oct 2017, 7:13 pm   #21
Lloyd 1985
Lloyd 1985's Avatar
Default Re: 1981 Philips 20CT3322/61Z. To plug it in or not?
Any flashes on the screen on switch off? Did you try the brightness and contrast settings? So far it doesn't sound bad, but the lack of raster doesn't sound good either! The flyback / LOPT should be making a very high pitched whistle, you probably won't hear it, the buzzing I'd expect to be coming from the scan coils, and the buzzing would be at frame rate. Can you feel any static build up on the CRT face?
Lloyd
Lloyd 1985 is offline   Reply With Quote
Old 26th Oct 2017, 7:19 pm   #22
dj_fivos_sak
Yes. the screen did a bright flash like most CRT sets do when they power off. As you stated, the buzzing is from the scan coils.
Fivos
dj_fivos_sak is offline   Reply With Quote
Old 26th Oct 2017, 8:45 pm   #23
nigelr2000
nigelr2000's Avatar
Looks like the type that had a battery backup so all levels will be at 0 as the battery will be failed by now, turn the brightness up again and look for a raster. same with colour and contrast, some of them came on full volume when the battery was flat. Die hard customers would set the levels and channels every time they came on rather than spend out on a repair. It was common to get sets in after people had been away on holiday as all the setting and channels would reset when not powered for a while, " it was ok before we went away" the lack of brightness fooled them into thinking the set was dead
nigelr2000 is offline   Reply With Quote
Old 27th Oct 2017, 7:37 am   #24
Heatercathodeshort
Heatercathodeshort's Avatar
Yes! Very common around June, July and August. J.
Old 27th Oct 2017, 12:39 pm   #25
Welsh Anorak
Welsh Anorak's Avatar
Gradually increase the brightness with the + button - ISTR these took a while to respond so give it time. You should see something on the screen. Since you've established it's quite happy with no arcing or smoke then leave it on a while. I assume you have CRT heaters and EHT because of the flash on the screen on switching off. This shouldn't be too difficult!
Glyn
Welsh Anorak is offline   Reply With Quote
Old 27th Oct 2017, 1:32 pm   #26
dj_fivos_sak
I increased the volume and the sound is working. I tried adjusting the contrast, brightness and verical hold but the screen is still black. Should I leave it plugged in and wait until it warms up?
Old 27th Oct 2017, 2:48 pm   #27
Philips210
Hi.
I would next try increasing the setting of the G2 control to see if there's a raster. First off though make a note of it's position before adjustment. The next step would be to check the tube base voltages. The G2 voltage should be around 400V on pin 10 of the crt. The cathode voltages should be about 150V on pin 3 (Blue), pin 8 (Red) and pin 12 (Green) of the crt. I can't quite recall what the G1 voltage should be, it doesn't seem to be listed on the circuit diagram. The focus voltage is quoted as 5.4kV.
EDIT: I seem to remember something about the 30V supply resistor going o/c causing a blank raster but it was a long time back. From my rough notes there's a servicing article on the KT3/K30 chassis in TELEVISION magazine Nov 1983 and I'm confident that I can find the issue. I could scan it but I don't have facilities to convert the files to pdf format so it can be uploaded here. I could always scan and send it to you by email attachments.
Symon
Philips210 is offline   Reply With Quote
Old 27th Oct 2017, 11:25 pm   #28
hamid_1
The November 1983 Television magazine is available online here: http://www.americanradiohistory.com/...UK-1983-11.pdf
Article on servicing the KT3 chassis starts on page 22.
The full service manual for your TV can be obtained from freeservicemanuals.info
Link is here, but the manual is not online at the time of posting. You can send an e-mail to request the manual; it will be added in a few days.
Meanwhile you can download the manual for a different KT3 model here:
http://freeservicemanuals.info/en/se...None/None/KT3/
Most of it will be the same. The service manual includes a useful fault-finding flowchart.
hamid_1 is offline   Reply With Quote
Old 28th Oct 2017, 11:05 am   #29
Philips210
Thanks hamid 1, I have to admit forgetting that the American Radio History website have many TELEVISION magazines for download. It's a really good resource, I've been going through the Radio Electronics magazines, very interesting.
Symon
Old 28th Oct 2017, 12:57 pm   #30
dj_fivos_sak
Very useful answer! Thanks. The KT3 manual looks exactly like my set. I sent him an email for my model.
Fivos
Old 29th Oct 2017, 7:14 pm   #31
Philips210
Hi.
There seems to be an anomaly with the American Radio History website in that the Nov 1983 issue along with many others has been listed under "Practical Television" There's a section "Television" and there's only one mag from the 1980's listed which is Dec 1989. I would suggest anyone looking for Television magazines therefore look under it's earlier title Practical Television.
I think the two titles should therefore be consolidated to avoid any confusion or apparent unsuccessful searches.
Symon.
Old 29th Oct 2017, 8:02 pm   #32
Maarten
Could you by any chance take a picture of the type label? This model is interesting for me since it's a multistandard model with an unfamiliair execution number (/61).
To see what's the matter with the picture, you could try turning up the G2 (screen) voltage a bit. Also, keep in mind that the contrast is not controlled at the front, but on the back. You may have noticed this yourself but contrast turned all the way down migth result in no picture in this model, I think, so I should mention it.
Maarten is offline   Reply With Quote
Old 29th Oct 2017, 9:32 pm   #33
dj_fivos_sak
Here you go. The "ΑΡ. ΑΔ." means license number. And it's actually May 15th 1981, not May 25th as I stated in post #1.
Old 29th Oct 2017, 10:27 pm   #34
Philips210
Which is what I pointed out in post #27
Symon
Old 30th Oct 2017, 1:13 am   #35
dj_fivos_sak
I forgot to ask, what is this adjustment for?
Fivos
ID:	151592   Click image for larger version
Old 30th Oct 2017, 2:10 am   #36
Maarten
Possibly the sound volume preset. It's a long time ago since I service a similar set with such a control.
Thanks for the picture, the label is quite interesting! A font almost like hand drawn, and it doesn't state a factory of origin (no letters in front of the serial number). It may have been made locally in Greece at least partially from imported parts. Are there any other paper labels on the chassis itself or only a duplicate of the same type label?
P.S. The date on the type label might be the date of the approval for the license for this model. If another label is present on the chassis, it might reveal the year and week of production as is customary in most Philips sets.
Old 30th Oct 2017, 2:16 pm   #37
dj_fivos_sak
Yes. It's indeed assembled in Greece. I've seen lots of Philips sets that were assembled here. It has another sticker on the chassis which is from the same date.
Fivos
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
Copyright ©2002 - 2017, Paul Stenning.
