Old 11th Nov 2016, 12:25 am   #101
Phil G4SPZ
Phil G4SPZ's Avatar
Default Re: Old torches - anyone here collect them?
I certainly remember the No 8 battery being marketed in the UK by Ever Ready bearing the 'Bijou' name. I guess the individual cells were something like modern 'sub-C' cells in size.
On a broader note, does anyone share my recollection that torch batteries in the late 1950s and 1960s were expensive, worked OK for a short while when brand new, but thereafter deteriorated quickly to a 'brown-out' and were prone to leak?
Phil
Phil G4SPZ is offline
Old 11th Nov 2016, 2:22 am   #102
emeritus
I got through dozens of blue Ever Ready U2's throughout the 1960's for my EL3585 tape recorder, and never had any leak. Prices were stable then, and a set of 6 cost 4/-. When the leakproof ones with predominantly white cases (SP2?) came out ( I think they may have been marked "sealed" rather than "leakproof") , they cost 5/-. I only got sets of them when I couldn't get the blue ones. They did leak! Both types lasted for about the 20 hours specified in the Philips instruction booklet when used for about an hour a day. As the recorder drew about 100mA, this works out at about 2Ah capacity. I usually had three sets on the go that I rotated to allow them to recover. I did try a set of the high power ones when they came out (HP2, orange case), but the recorder's speed regulator couldn't cope and ran too fast, whether because they produced a higher voltage or else their internal resistance was too low, so I never tried another set and can't comment on the effectiveness of their leakproofing. For comparison, in 1968 a packet of 20 Embassy cigarettes cost 4/6d and a gallon of petrol cost about the same.
emeritus is online now
Old 11th Nov 2016, 10:14 am   #103
I'm sure I can remember cylindrical batteries such as U2's being supplied in a continuous cardboard tube. The shop keeper would slice off the number you required.
Station X is offline
Old 11th Nov 2016, 11:18 am   #104
IanNVJ35
IanNVJ35's Avatar
Those tubes were what you were supposed to use in the Ever Ready metal torches in the 20's and 30's - using loose cells makes for a really bad rattle and flickering. In my three cell light I use a solid one piece holder that takes 12AA batteries (two stacks of 6 in parallel, 4 across) with a charge socket in the base and so I run 6 Volt lamps. Using Eneloop rechargeable cells gives about 8 hours of white light.
Just finished restoring a 'bullseye' lamp - all contacts were so open circuit that it would have passed a 3kV flash test! All fixed and down to under 0.2 Ohms, new 3.5V, 0.3 A bulb and 8AA battery holder fitted, along with regulator. Run time of undimming light is 30 Hours! The regulator will run the 8AA's down to almost complete exhaustion without yellowing.
It is light oak, but looks darker in the photo.
https://www.dropbox.com/s/kuyq9xpco1...33931.jpg?dl=0
and the beam
https://www.dropbox.com/s/c03oefusan...33823.jpg?dl=0
IanNVJ35 is offline
Old 11th Nov 2016, 11:20 am   #105
Nicklyons2
Nicklyons2's Avatar
When the zinc pot, cardboard covered range was being retired the predominently white ones were originally (and briefly) labelled LP2, LP11 etc. The LP being, supposedly 'leakproof' which, as said, they weren't. There appeared to be a hasty re-labelling to SP2 etc (which I understood from the 'rep' to be 'special') to get them out of any potential difficulties with, what was then in it's infancy, customers' rights/trade descriptions.
Ray-O-Vac had 'U2's with a green tamper strip over the positive and boasted and seemed, largely to achieve, leakproof status and backed it with an offer to replace anything in which their cells had burst and caused damage.
Nicklyons2 is offline
Old 11th Nov 2016, 12:58 pm   #106
radioman
radioman's Avatar
Well this one hasn't leaked and even has some life left in it. (Not much though - voltage drops to 1.2V with a 1k load)
It was recently removed from an old multi-meter and had been soldered in position.
Would this battery date from some time in the 60's ?
Regarding old torches, I had a Pifco one (haven't seen it for a while...) with a chromed metal case with red and green coloured filters that could be slid in front of the bulb.
Andy
Last edited by radioman; 11th Nov 2016 at 1:08 pm. Reason: Update on battery voltage
radioman is offline
Old 11th Nov 2016, 9:32 pm   #107
Lloyd 1985
Lloyd 1985's Avatar
Originally Posted by IanNVJ35 View Post
If you go back to that shop... Maybe make an offer?
Well, I have been back, and it seems to have followed me home this time! It's slightly different to the Ever ready ones I've seen so far, the switch is the other way round for a start, and the back slides off downwards. There isn't any makers name on it at all, the price tag said 'Niagara searchlight' (they take the tags off in the shop..), I have found nothing on it online, although there was a company called Niagara that made torches. All the Ever ready ones I've seen are in plain polished wood, not covered in this green leather type stuff.
It's in nice used condition, the bullseye lens is scratched quite badly, but the case is good. Someone has done some odd re-arrangement of the battery terminals in the past, I couldn't make any sense of them, so I moved them to the same positions as in IanNVJ35's photo's. One bit of brass is missing, so I'll make a new bit up. Getting to the bulb holder was fun! I thought that the lens would unscrew from the front, and leave the reflector and bulb holder exposed; oh no it doesn't! You have to remove the 5 screws around the bezel, and the whole thing comes off. The reflector has some dimples in it, and unfortunately some corrosion too, I might try polishing it a bit, but I don't want to damage it further. There is a odd threaded piece that screws on round the lens, not sure what it's for? Maybe it was a coloured filter at some point, and the glass has dropped out or gotten broken.
I've fitted a 3.5V bulb, and a 4.5V battery, there was enough room for my croc clip leads! The lamp works nicely, with a bit of flicker from dodgy switch contacts, and it casts a lovely big circle of light with funky patterns round the edge, presumably from the dimples in the reflector. There is a date on the switch of 1914, it may have been made after that date, but it holds the record of the oldest torch in the house!
All in all a nice little torch, even if it was a bit expensive...
Lloyd.
ID:	132630   Click image for larger version
ID:	132631   Click image for larger version
ID:	132632   Click image for larger version
ID:	132633   Click image for larger version
Lloyd 1985 is offline
Old 11th Nov 2016, 9:35 pm   #108
Lloyd 1985
Lloyd 1985's Avatar
More pictures....
ID:	132636   Click image for larger version
ID:	132637   Click image for larger version
ID:	132638   Click image for larger version
ID:	132639   Click image for larger version
Old 11th Nov 2016, 9:36 pm   #109
Lloyd 1985
Lloyd 1985's Avatar
And the last 3
Just a thought, would anyone happen to know what bulb was fitted originally and what battery? Anyone got an original battery so I can copy it?
Lloyd.
ID:	132641   Click image for larger version
ID:	132642   Click image for larger version
Old 12th Nov 2016, 10:54 am   #110
IanNVJ35
IanNVJ35's Avatar
Well done Lloyd for rescuing the light. And what a lovely light it is! Its most certainly an Ever Ready at heart, but the covering and glass orb are not - and were fitted by the company that sold them. I wonder if they bought in part assembled lights or just the parts? Don't suppose we will ever know. I have details on the original bulbs and batteries - I will add when I have dug them out.
IanNVJ35 is offline
Old 12th Nov 2016, 6:01 pm   #111
emeritus
Here's a scan of all the Osram battery bulbs that are listed in the almost-contemporaneous GEC catalogue for 1911. Most are supplied in 2V voltage increments for use with accumulators, and there is only one page of non-2V-step bulbs intended for use with dry batteries. The master index lists batteries and hand lamps, but they are in parts of the catalogue that I do not have. You would need to consult the comprehensive collection of old GEC catalogues that are held in the Bodlian Library at Oxford as part of the Marconi collection.
Re #109, I would think that it would be earlier than 1965, as my recollection (not 100% these days) was that the only white batteries I had featured the present Ever Ready logo that has smooth curves at top and bottom. Yours has the older wavy curve design. That is consistent with the observations made in #108 on the change of labelling, and would make it around 50 years old. Not bad!
Old 12th Nov 2016, 6:53 pm   #112
Over 100 years old (one bit anyway!) and still going, super job.
Old 12th Nov 2016, 7:46 pm   #113
IanNVJ35
IanNVJ35's Avatar
Right, first photo is of the bulb that would have been fitted. It is 3.5V, 0.3A with U filament. This means that the central beam spot given is much larger, more spread out - and with an illuminated U as part of the beam. The 2.5V, 0.3A S filament bulbs also work well, with 3 Volt supply. What bulb have you fitted? To get close to intended as possible you need a bulb with as low set and long filament as possible.
Second photo is of the Ever Ready version of your light - same handle and catch on the back, but mine has a watch glass type front lens. I fitted a bulb of my own making - Xenon Mag bulb, potted into a MES holder - it did not like modern bulbs at all.
Third is the Ever Ready design 'Bullsi' (correct spelling) - you can see the glass is much thicker - and another photo shows all the bubbles that glow.
Well done on getting yours working, and the flickering switch can be cured by cleaning all contacts with a glass fibre pen - check the underside cointacts too - these are usually high impedance due to corrosion. The whole circuit should be 0.2-0.3 Ohms, any more and you have a weak spot. Solder can be used if needed.
This is the battery the lamp would take (not my photo) http://i41.photobucket.com/albums/e2...mage176a-1.jpg
I use a buck circuit in all my lamps - stops any flicker and makes the bulbs last a long time.
ID:	132695   Click image for larger version
ID:	132696   Click image for larger version
ID:	132697   Click image for larger version
ID:	132698   Click image for larger version
IanNVJ35 is offline
Old 12th Nov 2016, 8:53 pm   #114
Originally Posted by Nickthedentist View Post
Talking of special bulbs, the motoring torches with flashing red beacons and a spring-terminal lantern battery usually took a tubular MES lamp with an integral bimetallic strip to provide the flashing action. I can still remember that the initial "on" period was slightly longer than subsequent ones, as the thing came up to operating temperature.
Yes - that's exactly what I remember. The bimetal strip was heated by the bulb filament - a rather neat way of getting the flashing-action without needing to waste any power in a separate 'heater' winding for the bimetal.
Old 13th Nov 2016, 1:04 am   #115
Lloyd 1985
Lloyd 1985's Avatar
Hi Ian,
The bulb you show looks interesting, The ones I bought (the box is shown in one of my pictures) are 3.5V 0.3A with a straight length of coiled filament. Probably not ideal, as the filament sits quite high up inside the bulb, maybe I'll have a look at some of the xenon bulbs you mention, and fit them to bases of dead bulbs! I've just created one such bulb that can donate it's base, turned out the glass was as thin as paper, and trying to unscrew it from my rusty Ever ready resulted in a pop, and 3 shards of glass embedded into my finger! Not pleasant...
I'm getting quite a liking for these old lights, they really do look nice, and as Merlin Maxwell said 100 years on and still going - and without (much) modification, built to last would be an understatement!
To bring it into the modern age I might see about making up a replica battery using a couple of rechargeable Lithium bombs, and some regulator circuitry. I'll draw the line at fitting some sort of LED replacement bulb.
Lloyd.
Old 13th Nov 2016, 10:28 am   #116
IanNVJ35
IanNVJ35's Avatar
It's good that you are enjoying tinkering with these lovely bits of old technology. That they can be made to work better than new is a real plus - I just know that the original designers would be well pleased to see what we are doing. If you look on eBay there are some small adjustable regulators which work well. I set them up with switched negative - so the regulator comes into circuit AND the bulb lights at the same time. I used cable blocks with a small slot cut in so I can clamp to internal parts without solder. Keep us posted!
IanNVJ35 is offline
Old 13th Nov 2016, 11:10 am   #117
emeritus
A large proportion of the torch bulbs in the 1911 catalogue are of the "Flat with opal glass reflector" type, where the filament was clearly much lower down than in the types presently available. I remember as a child in the mid-1950's being given what must have been a pre-war torch that had such a bulb, but the bulb was blown and I remember that I couldn't get an exact replacement. I guess there can't be too many original bulbs around now. I remember my school physics master mentioning that torch bulbs were over-run to give a bright light at the expense of lifetime, and a book on the US lamp industry mentions that, for a period in the 1930's, the American GE redesigned their torch bulbs to only last for two sets of batteries.
Old 13th Nov 2016, 3:34 pm   #118
IanNVJ35
IanNVJ35's Avatar
Here are a few from my collection. First is one of those from the 1911 catalogue - you can see the glass is white at the back - to be used with torches with bullseye but no reflector. It is overdriven at 3.5 Volts - real rating is more like 3.
Second is a smaller diameter version.
Third is an Ever Ready type.
Fourth is a 1930's Ever Ready - now with coiled filament but still set low into the bulb as per the old range. When buying old torches, these are more common and work well, just losing a bit of character compared to the very old bulbs.
Last is something I knocked up - a Lilliput to MES holder that works well with older torches - because the filament is low down.
ID:	132736   Click image for larger version
ID:	132737   Click image for larger version
ID:	132738   Click image for larger version
ID:	132739   Click image for larger version
IanNVJ35 is offline
Old 13th Nov 2016, 8:29 pm   #119
Techman
Techman's Avatar
Originally Posted by Colourstar View Post
As a torch & battery obsessed child
You and me both, Steve
Originally Posted by suebutcher View Post
The "under pillow" Ever Ready torch was introduced in 1965.
That's about the when I remember this torch from (picture of this torch shown in the last two photos in post #53). My grandmother died in 1966 and I suspect that this is where this torch came from.
Techman is offline
Old 13th Nov 2016, 9:28 pm   #120
Techman
Techman's Avatar
There are some very nice examples of vintage torches being shown, many of them much older than the examples that I have.
Shown below is the screwdriver torch with three out of the four original bits. Also, the Readers Digest pen torch that lives permanently in the top pocket of my leather jacket - none of this modern LED torch stuff for me In the pictures can be seen a lens which is all that remains from some forgotten torch, probably once belonging to grandparents - I seem to remember the torch it came from and which probably was the victim of rotten batteries. The copper plated 'oil lamp look-alike' I've had for a lifetime and is a bit of a rare survivor, having suffered from rotten batteries many years ago. It has a three position and off switch and originally had three bulbs, white, green and red flashing. It now only has the white light bulb which could actually be the green one with the colour rubbed off. The long, red flashing bulb I remember breaking as a child when I tried to fit it into a torch that it was too long for - probably the other torch of the type shown by me in post #17, but which as well as having the coloured cylinders which slid up round the bulb, also had a 'focusing' arrangement which adjusted the lens in and out and probably crushed the bulb as it was turned back down nearer to the reflector. The copper plating is no longer in good condition on this lamp but with a bit of cleaning and bending of the contacts it produced light for the first time in around fifty years. A word of warning with these old torches and modern batteries - they were made in the days of cardboard cased batteries and modern metal cased cells/batteries can short out/cause leakage between the internal contacts in these old lamps, as I found out when I left it over night to find it was only giving half brightness the next day. One of the two 'C' cells was dead due to its metal case causing leakage of current - lucky it was just a 'Poundshop' zinc carbon, as an alkaline type supplying a much higher current could have caused things to get a bit hot!
Originally Posted by Phil G4SPZ View Post
I think I have some of these somewhere, in a packet confusingly labelled 'flashlight bulbs'...
If these are the long form red type, then this is exactly the type with the internal bi-metal strip that was originally in this lamp and I would love to be able to find a replacement for this lamp and wonder if you would be able to spare one. However, if these are part of a set in an original packet or for what ever other reason, then I quite understand if you would rather keep them complete.
Pictures below:-
ID:	132758   Click image for larger version
Techman is offline
