7th Feb 2011, 12:24 am | #1 |
Three Pye B16s to restore.
I intend to restore these receivers to full working order.
The chassis assemblies shown in the foreground are my first priority as they belong to a form member. The complete receivers are mine. On the left side of the picture is a rather beat up Pye and on the right is the Invicta version. T100? I know that all three have faulty slider controls so I will have find some alternatives as replacements. Those slider controls apart the B16 is an easy set to get going. Forum member HKShort has reminded me that the Visconol EHT capacitor is almost certainly faulty or will become faulty in use. I have a replacement supplied from "frag Jan zuerst" I have not much of the modern stuff to repair so I'd better take the opportunity to sort out some vintage TVs instead. I guess it's all those +65 folks thats doing the LCD TV work. DFWB. |
7th Feb 2011, 2:05 pm | #2 | |
Re: Three Pye B16s to restore.
I have replaced one set of D16T sliders, as three were open circuit, with a panel like the one shown. 5W wire-wound pots from Digikey in the US (no connection etc.) and a tufnol panel made to fit the brackets used for the sliders. Does not look original but it works very well. |
7th Feb 2011, 9:44 pm | #3 |
Dear David,
Should you need encouragement + proof that you're doing a great job, look at one of your beauties at Gateshead's Shipley Art Gallery last weekend (fully working, hurray) See you soon Silvie |
7th Feb 2011, 9:57 pm | #4 |
I have one of those somewhere ...
There are nice little sets ,Take up little room too |
7th Feb 2011, 10:18 pm | #5 |
7th Feb 2011, 10:32 pm | #6 |
Hi Brian,
by fitting those high quality rotary pots as replacements for the front slider controls the problem is solved for good. They are hidden when cover is in place. I've still got the rear pre-sets to sort out though. Hi Chipp, They are amazingly small sets when one considers the monster receivers that were around in 1946. Pye were good making compact TV receivers. The pre-war 815 and 915 chassis were quite compact as well. DFWB. It's 9:30 PM. Let's see how much I can get done on the B16 receivers. |
7th Feb 2011, 10:41 pm | #7 |
Hello David.
I am sure you will rattle through the little PYE's with ease. I also like the GEC that you did for Silvie. Brian that is a nice little paxolin plate and controls you made up. I also have an idea for the controls in the B16 & 18 models, I have already suggested my idea to David. I was going to fit pots on a plate either at the bottom or the top of the chassis with the shafts vertical, having the same spacing as the original sliders. A skew thread would be machined into the shafts and the sliders modded with a suitable ball end to engage into the skew gear/thread, sliding the knob up and down will then rotate the control.
Cheers, Trevor. MM0KJJ. RSGB, GQRP, WACRAL, K&LARC. Member |
7th Feb 2011, 11:58 pm | #8 |
The front slider controls appear to be OK. I'll fire up the power unit tomorrow.
DFWB. |
8th Feb 2011, 12:14 am | #9 |
Hi Dave. The panel was made for the rear controls although, as you say, the same method could be used for the front controls. However, the spacing and depth of knobs would be critical due to the window and sliding door.
8th Feb 2011, 11:56 pm | #10 |
The power supply unit is very rusty and some of the rubber covered wires need replacement before there is any attempt to connect it to the mains supply. I will use the variac to give the old electrolytic capacitors a chance of survival.
The second and third pictures show the Brimar 6AG6 sound output valve. The 6AG6 is a direct replacement for the Mullard EL33. The Brimar valve was actually made by Osram. DFWB. |
9th Feb 2011, 9:20 am | #11 |
Hello David,
I have two of these fantastic receivers and have owned them for a very long time. Up with the very best if not the best receivers of 1946/47. How they get that brightness from a MW22-7 tube defies me. Rectifier valves were difficult to obtain immediately after the war and some versions have Mazda UU8 valves and others the Mullard GZ32. The mains transformers usually look like it has been fried with all the wax drippings but this is quite normal and I have never had a failure even when receivers have been stored in very bad conditions. I will 'plug 'em in' before the weekend and take a few pictures. The mains derived EHT is nearer 6kv than 5 on these models, take great care! Easy projects David. I wish you were closer, then we could sort them out together. Regards, John. |
7th Mar 2011, 12:21 am | #12 |
I have reformed the electrolytics in one of the power supply units.
My favorite method to reform the caps is to supply them from the mains though a series connected 1N4007 diode and a high value resistor, usually 180Kohms. To start the the reforming process for this power supply unit I chose three resistors of 82,000ohms, it took quite a long time for the voltage across the capacitors to come up to 190 volts. For the next stage I connected a 68,000 ohm resistor across each 82K resistor. Again it took quite while for the voltage across each capacitor to reach the indicated 310 volts. I'm certain that the capacitors are now OK because it takes a long time for them to discharge. Some people find that this reforming technique is a bit scary, but it works for me. DFWB. |
7th Mar 2011, 1:25 pm | #13 |
That looks like a good job to me David, I would suspect the caps are A OK and will be fine once the set is complete.
