View Poll Results: Will the radio work when turned on at 4PM? | |||
YES | 2 | 10.00% | |
NO | 18 | 90.00% | |
Voters: 20. You may not vote on this poll |
3rd Dec 2021, 5:16 pm | #281 |
Re: Pilot Little Maestro pre war AC/DC 1939 restoration project.
IT LIVES
But!!! the audio is very distorted and not very loud. The oscillator is very strong on MW, Few measurements. Rectifier 180 volts 6A8 Anode 140 volts, Overall current draw = 0.358ma Volume pot bypassed as it's dodgy. Yea radio dave the switch is now on the live side
Help!! I've been electrocuted by a glass thing that glows |
3rd Dec 2021, 5:34 pm | #282 |
Are you sure about the current drawn? Is that the current drawn from the mains or the HT supply?
3rd Dec 2021, 5:38 pm | #283 |
That's the overall current draw meter in line with the mains plug
3rd Dec 2021, 6:42 pm | #284 |
3rd Dec 2021, 6:48 pm | #285 |
Is the decimal point in the right place?
3rd Dec 2021, 7:12 pm | #286 | |
3rd Dec 2021, 8:37 pm | #287 |
Well done, sounds at last!
How have you bypassed the volume control? It's also the signal diode load so that still needs to be about 250k. |
3rd Dec 2021, 8:54 pm | #288 |
I just realised that, Volume pot is dodgy, I hooked it back up temporarily and she sounds fantastic
3rd Dec 2021, 8:59 pm | #289 |
Much obliged to all that contributed to the thread, Thought it would never end All i need to do now is try and fix the volume pot or source a new one,
By the way the HT resistor only gets slightly warm. Heres hoping i don't need to reactivate this thread Cheers all
3rd Dec 2021, 9:21 pm | #290 |
That's better!! I was going to say that at 35 microamps, it wouldn't be working at all!. Well done on finally cracking the case. It's certainly been a learning curve!
3rd Dec 2021, 9:33 pm | #291 |
For sure yeah, In the end what stopped it working when i first tried it was V1 installed the wrong way round due to a worn key in the valve base and a bad volume control, Glad it wasn't an error in my work
3rd Dec 2021, 11:33 pm | #292 |
That was hard work for your first resto, congrats on your efforts (plus others )
enjoy dave h |
7th Dec 2021, 2:13 pm | #293 |
Cheers dave
Just when you thought you'd seen the last of this thread i'm back, An issue has cropped up and was being discussed in my potentiometer wanted thread, But that's not the place to discuss it, Hence i'm back here again. Story is The way the volume pot works seems to puzzle me, It's got a centre notch like a balance control. When in the centre notch position the resistance is zero between the two outer pins which causes a short and blows the fuse. Far as i know the resistance between the two outer pins should be constant, First half of the wiper is around 660k and can be varied, Second half is constant, When i was adjusting the volume yesterday i saw a flash then the fuse popped, Second time it's happened whilst adjusting the volume. Seems that when the two outer pins on the pot drop to zero ohms L11 Is being shunted to ground, But L11 Shouldn't have any real voltage across it, Even if it did you'd think the coil would burn out before the fuse blew. Very strange. Jay
7th Dec 2021, 4:50 pm | #294 |
SOLVED
One side of the on/off switch goes to the chassis, But only when the switch is in the Off position, As for the volume control, I must have reassembled it wrongly, Centre notch is now gone and it works perfectly, Another lesson learned, Although i thought it originally had a centre notch, But couldn't figure out why..
7th Dec 2021, 5:05 pm | #295 |
One side of the switch should go to chassis no matter what the switch's position. When the switch in in the ON position one side of the mains (preferably neutral) is connected to chassis via the switch.
7th Dec 2021, 5:11 pm | #296 |
Does your set have a single or double-pole on-off switch?
If it is a single pole switch it is better to connect it to the live mains. However, if the volume control needs replacement, fit one with a double pole switch. DFWB. |
7th Dec 2021, 5:11 pm | #297 | |
Problem was i rewired the switch to switch the live not knowing about the above, I thought switching the live was preferred ?
7th Dec 2021, 5:18 pm | #298 |
Regardless of whether the switch is in the live or neutral lead it shouldn't blow a fuse.
You haven't earthed the chassis have you? EDIT. It must be the input or mains lead side of the switch which is grounded in the OFF position. This will short circuit the mains supply no matter which way round it's connected.
7th Dec 2021, 5:40 pm | #299 | |
8th Dec 2021, 2:25 pm | #300 |
finished - the end
