Old 15th Nov 2021, 6:27 pm   #401
ajgriff
ajgriff's Avatar
Default Re: Commodore PET 2001 voltage regulators
That's odd Tim. I suppose I could be mistaken about the three prongs. Let's see if anyone else has a view.
Alan
ajgriff is offline
Old 15th Nov 2021, 6:33 pm   #402
retromit
Alan
Thanks, Alan. Looking at the area on the CRT where everything has to go, it really doesn’t seem very deep; so not sure if the two longer prongs should sit inside (which they can), then the smaller clip rests on the metal rim on the outside? I’ve tried to get the smaller clip in first, but as soon as the longer prongs go in, then the smaller clip pops out.
Tim.
retromit is offline
Old 15th Nov 2021, 7:09 pm   #403
SiriusHardware
I have to admit that, with the smaller bit being electrically connected to the two longer bits, it does seem that the smaller bit should go inside the tube as well. I could be wrong though.
Did you (Tim) remember what we said about how pinching the round centre part on the cap from the sides should make the two prongs retract inwards towards each other so they will fit through the hole they are supposed to grab onto from behind when they are released? If you do that, does that allow the prongs + extra bit to go deeper in?
I wonder if AJ or Colin might be able to look to see what theirs looks like in-situ, after discharging them first of course. Maybe Colin might remember having to negotiate the same problem. The main thing to note is whether there is a dark coating on the main body of the tube, and then to observe how close to the edge of the hole it approaches. Normally there is a fairly wide un-coated gap surrounding the hole.
If that's the case here as well then maybe that bent 'hook' is supposed to be the 'spring' which pulls the hooks on the ends of the prongs firmly up against the inside of the hole, in which case it may well be meant to rest on the outside of the hole.
SiriusHardware is online now
Old 15th Nov 2021, 7:36 pm   #404
ajgriff
ajgriff's Avatar
Done. Only the two splayed prongs sit in the recess and the curved part rests against the outer surface. Life is full of surprises.
Alan
ajgriff is offline
Old 15th Nov 2021, 7:38 pm   #405
retromit
Alan
That’s great - thanks for doing that, Alan. Right, I should now be able to get the two prongs in, then get ready for testing.
Thanks again,
Tim.
retromit is offline
Old 15th Nov 2021, 7:46 pm   #406
ajgriff
ajgriff's Avatar
Having caused the confusion in the first place Tim, I was obliged to take a look. Better still the PET is still working!
Alan
ajgriff is offline
Old 15th Nov 2021, 8:03 pm   #407
retromit
Alan
It’s good news the PET is still working! Thanks once again. I’ll go and get the cap attached, then look at getting it connected to the PET. Fingers crossed!
Tim.
retromit is offline
Old 15th Nov 2021, 9:08 pm   #408
retromit
Everything has been put back together and the monitor mounted onto the PET. I'm pleased to say it all still works!
That's a big relief, and not something I'd really like to do for quite a while again! A really fiddly job trying to get the CRT in (and out) of the case. Thanks again for all your help and support.
The gloss paint had hardened well, and it certainly looks better inside the monitor case now. Hopefully the rust is now a thing of the past. The PCB also had a light clean, as well as the anode cap. I've kept the cable airbourne as SiriusHardware mentioned (sorry, I had to google LOPT!), and it's not touching anything, nor the case.
Next job is to finish off the case, then we're onto the keyboard.
Tim.
ID:	245897   Click image for larger version
retromit is offline
Old 15th Nov 2021, 10:02 pm   #409
SiriusHardware
Oops, I did it again, yes, LOPT = Line OutPut Transformer, that chunky thing which the thick, high voltage cable comes out of.
It looks very smart now, well done.
Old 16th Nov 2021, 2:09 pm   #410
ScottishColin
Good work. The PCB is nice and clean too.
Getting there.
Colin.
Tim.
ScottishColin is online now
Old 16th Nov 2021, 6:40 pm   #411
ajgriff
ajgriff's Avatar
If the keyboard is still working well without any sticky or erratic keys I'd be tempted to just remove it, give it a good skake upside down and then simply clean the keys with a moist cloth without removing the caps. Don't see the point in disturbing things just for the sake of it.
Alan
ajgriff is offline
Old 17th Nov 2021, 6:08 pm   #412
ScottishColin
You have no sense of adventure.
Colin.
Alan
Old 17th Nov 2021, 6:30 pm   #413
ajgriff
ajgriff's Avatar
True and I can't type accurately either (skake!?).
Alan
ajgriff is offline
Old 17th Nov 2021, 10:24 pm   #414
retromit
The case has now been cleaned, so they keyboard beckoned. It turned into a rather large job. On taking out the keyboard, I was hoping I might get away with what Alan suggested; however, the keyboard was absolutely filthy. So I ended up having to remove the keycaps in order to give it a good clean, then the keyboard itself. After a lot of cleaning, it was put back into the PET and all works as expected. So another job off the list!
Tim.
ID:	246024   Click image for larger version
retromit is offline
Old 17th Nov 2021, 10:26 pm   #415
retromit
All of the exterior cleaning has now been done; screen, casing, and keyboard. The rust has been addressed in the monitor case, and the very small specks on the case have had a drop of the rust neutraliser. The whole lot has then had a polish. I don’t think I’ll do anything further as I think it looks okay now.
With that now done, it’s time to address the inside of the case (mainly dust again in the bottom under the PCB), and the transformer.
It's getting there.
Tim.
ID:	246026   Click image for larger version
ID:	246027   Click image for larger version
retromit is offline
Old 17th Nov 2021, 11:13 pm   #416
ajgriff
ajgriff's Avatar
Stunning! Strange to think that this thread started with a question about voltage regulators.
Alan
ajgriff is offline
Old 17th Nov 2021, 11:34 pm   #417
Red to black
Red to black's Avatar
The two prongs fit in the crt cavity, the third bit stays in the final anode rubber cap, don't worry about it, it is only a monochrome crt, the voltages here are fairly low compared to colour tubes.
Red to black is offline
Old 18th Nov 2021, 11:53 am   #418
retromit
Alan
Thanks, Alan. Yes, all started with no 5V in the PET and the wrong assumption (on my part) that it could have been the voltage regulators! It's certainly come a long way, and I couldn't have done it without the help from all of you on the forum.
Thanks once again!
Tim.
retromit is offline
