Old 22nd Feb 2021, 11:35 pm   #1
JaySpark
Default Smiths Sectric Wall Clock De Luxe Movement
Hello
Iím new here and after finding your site, reading some posts and hearing your wealth of knowledge, I thought Iíd hop in and see if you can help!
I have been tasked with looking into why a friends Smiths Sentric Wall clock is running slow. Some days itís as much 20 mins others itís 5 mins it varies.
Ive been searching around and believe the movement to be a De Luxe (but please correct me if Iím wrong) I have no knowledge of clock repairs electric or mechanical but, I am an electrician and also very interested in repairing all sorts of items, mainly to see how they work and also why they stopped! Just love the way things ďuseĒ to be made!!!
Ive attached a few photos below so hopefully someone may be able to answer if what I feel could be the problem
1, There appears to be quite a lot of thick grease (beige colour) on both of the worm gears. Is this too much grease?
2, Should this grease be cleaned and fresh grease applied? If so, any recommendations for a type of grease?
3, As it is apart, I was going to oil the pivot points. Am I right in thinking there is really two on this movement?
Any help would be greatly appreciated
ID:	227384   Click image for larger version
ID:	227385   Click image for larger version
ID:	227386   Click image for larger version
JaySpark is offline   Reply With Quote
Old 23rd Feb 2021, 12:03 am   #2
John_Dw
Default Re: Smiths Sentric Wall Clock De Luxe Movement
My money is on that due to old oil/dirt and varying temperature, where it is kept, it is actually intermittently stopping and re-starting itself, giving the impression that it is running slow........
John_Dw is offline   Reply With Quote
Old 23rd Feb 2021, 1:18 pm   #3
JaySpark
Many thanks for the prompt response. Are there any particular grease and oils I should be looking at to re-lubricate??
Old 24th Feb 2021, 11:48 am   #4
JaySpark
Itís a very good point whether the clock is stopping and starting again or if is running slow. I suppose itís a little difficult to find out for sure without watching the movement for a long period of time to see if it actually stops.
I ll go with the cleaning off the old grease and re-lubricating. Just need to work out what the recommendations are for the new grease and oil.
Any suggestions??
Old 26th Feb 2021, 9:23 am   #5
Mike Phelan
Mike Phelan's Avatar
Hi (and welcome!)
BTW, it's Sectric, not Sentric.
It's almost certainly due to what John says - stopping and starting, as synchronous clocks only either run correctly or stop!
For a start, no oil or grease in the movement at all; it's really better to completely dismantle the movement, wash everything apart from the motor and oil with the correct lubricant, washing it assembled is a bit like having a bath with your clothes on
As I guess you're not completely au fait with clock repair then try just oiling pivots with car engine oil, removing the rotor and oiling the pivot with 3-in-1 or sewing machine oil.
Worth a check to see what fuse is in the plug - should be 3 amp.
Mike.
Mike Phelan is online now   Reply With Quote
Old 26th Feb 2021, 9:26 am   #6
Cobaltblue
Cobaltblue's Avatar
Default Re: Smiths Sectric Wall Clock De Luxe Movement
Title updated to Sectric.
Mike T
Don't care if it was a bargain why's it in my kitchen
Mike T BVWS member.
www.cossor.co.uk
Cobaltblue is offline   Reply With Quote
Old 27th Feb 2021, 8:52 am   #7
JaySpark
Hi Mike
Many thanks and also for the correction on Sectric!
I think I’ll strip it completely, wash all parts, apart from the motor as you suggest. Them reassemble with oiling the pivot points with a tiny drop of engine oil on each and some sewing machine on the rotor pivot as you say.
Can I ask, is sewing machine oil better than clock oil for the rotor on this type of clock?
Old 27th Feb 2021, 4:36 pm   #8
PaulR
PaulR's Avatar
Mike is our clock expert but I would suggest that you use sewing machine oil on the rotor. When you get it dismantled clean out the pivot holes using a cocktail stick dipped in IPA - or gin if you haven't any IPA to hand. IPA = isopropyl alcohol by the way not India Pale Ale !!
Keep changing the cocktail sticks until the tip comes out clean.
Paul
PaulR is offline   Reply With Quote
Old 28th Feb 2021, 8:45 am   #9
Mike Phelan
Originally Posted by JaySpark View Post
Hi Mike
You're welcome!
I think Iíll strip it completely, wash all parts, apart from the motor as you suggest. Them reassemble with oiling the pivot points with a tiny drop of engine oil on each and some sewing machine on the rotor pivot as you say.
Yes. Clock oil is made so it doesn't "run" - i.e. it needs to stay in the same place, whereas the rotor in a clock needs oil that can reach all parts of the bronze bearing and many of these are sintered - the bronze is made from a powder and acts a bit like a sponge.
Thanks, Paul, for the accolade!
Expert definition
Ex = has been.
Spurt = drip under pressure.
Mike.
Old 3rd Mar 2021, 10:09 pm   #10
JaySpark
Many thanks for the cleaning tips!!
Old 3rd Mar 2021, 10:13 pm   #11
JaySpark
Originally Posted by Mike Phelan View Post
Hi Mike
You're welcome!
Expert definition
Ex = has been.
Thanks again for your valuable knowledge!
One last question before I get on and strip the movement down. Is there a way to establish the age of this movement? Maybe from the markings shown in the photos? It would be great to give the owner a little more info on the clock when I return it to them.
