Old 9th Jun 2019, 7:13 pm   #161
Valvepower
Valvepower's Avatar
Default Re: Any other plug collectors out there?
Hello,
I’m in the throes of getting my late parents’ house rewired, and I just couldn’t let the original 1967 MK pug, which was fitted to the immersion heater, Wylex cartridge fuse consumer unit and Aerialite T.V Outlet all get thrown away!
Terry
Valvepower is offline
Old 11th Jun 2019, 5:38 pm   #162
Originally Posted by Herald1360 View Post
Originally Posted by G6Tanuki View Post
I've always wired plugs with equal-lengths to the terminals.
Surely equal lengths to the terminals only works if the terminals are laid out for equal length wires.
Normal best practice is to cut the wires to such lengths that the line and neutral wires follow paths with equal amounts of "slack" and the earth wire has additional "slack" so that in the event of a cable pullout the earth lets go last.
I should really have said "equal slack in all three conductors" rather than 'equal lengths'.
My argument being that _any_ pullout following cord-grip failure is an issue - both from the safety/hazard PoV and the fact that the equipment will cease to function. A partial-pullout of a short-wired 'live' - causing arcing but not immediate failure-to-function - is to me a serious hazard issue!
Equal-amounts-of-slack-in-all-conductors means any tension is spread equally over all 3 terminals - so the chance of a pullout of any conductor is reduced: equipment will continue to function (albeit with somewhat reduced safety but no immediate hazard) until the next inspection.
Though, like I mentioned, this sort of thing never appeared significant in the "top ten" reasons-to-reject during PAT or any other inspection.
[#1, from memory, was 'outer jacket damaged' - usually because some room-temperature-IQ type had dumped a steel filing-cabinet on top of the cable].
Old 21st Jun 2019, 7:33 pm   #163
I'm wondering who if anyone has another example of this Panasonic "Filtered Plug"??
It's a moulded-on one, fitted to a bit of Anritsu testgear I bought around 1999-2000ish.
According to the markings on the underside it's got a common-mode filter built-in. I guess that in times-past that was a good way to ensure compliance with EMC regulations?
ID:	185477   Click image for larger version
Old 25th Jun 2019, 10:19 pm   #164
Graham G3ZVT
Graham G3ZVT's Avatar
Several 5A two-pin sockets like this still adorn the skirting boards in a friends new (to them) house.
Graham.
G3ZVT
Graham G3ZVT is online now
Old 26th Jun 2019, 12:47 am   #165
kjshier
I get asked for 13 Amp BROWN Bakelite plugs all the time.
I couldn't find a single manufacture so I have taken the plunge and commissioned a production run. We will soon be adding them to our range.
kjshier is offline
Old 26th Jun 2019, 6:11 pm   #166
Brigham
Who's doing them? Ward & Goldstone?
I'll take a few.
Brigham is offline
Old 26th Jun 2019, 10:31 pm   #167
Graham G3ZVT
Brown Nettle plugs are evocative of my childhood. Most of our electrical items were fitted with them.
(b. 1953)
Graham.
G3ZVT
Old 6th Aug 2019, 7:05 pm   #168
Tom williams
Tom williams's Avatar
Originally Posted by Lancs Lad View Post
Originally Posted by rambo1152 View Post
I have got my very own Big Clive Chinese Deathdapter!
Oooh yes, Granada Graham! I have one of those aswell.
It looks, and is, absolutely lethal - everything about it is just so wrong. I was given mine by a well-meaning (I hope...) friend, but how on earth are these things allowed to be sold in this country?
There must be thousands of people using them who have no idea how electrically unsafe they are. It's frightening.
Hi Lans lad,
These deathdapters are absolutely awful and I have see some in use in an OLD PEOPLES HOME!
They were on some CHIP FRYERS!
Tom williams is offline
Old 6th Aug 2019, 11:04 pm   #169
Graham G3ZVT
Just a couple of things I have seen.
A "neon" style LED sign in a chemist shop window plugged into a 32A circuit with one of these
and an industrial conveyor type toaster plugged into a coiled-up (and hot) cable reel on the floor behind the table-cloth in a Premier Inn breakfast room.
Graham.
G3ZVT
Old 7th Aug 2019, 2:13 am   #170
Refugee
Refugee's Avatar
I tested one of those plugs like the one on the LED sign to destruction.
Mine was a C13 on the other end.
I made a lead with all three pins connected to a male to match C13 to the earth pin of a good 13 amp plug and connected it to an analogue PAT tester.
It read well over an ohm per conductor using the earth continuity function.
It would be scorching hot well before the 32 amp breaker tripped.
ID:	187962   Click image for larger version
Refugee is offline
Old 7th Aug 2019, 10:31 am   #171
hannahs radios
When my bank was being re designed inside they had a four way extension block fed with a thin looking flex which was supplying a oil filled radiator a computer and a printer the four way block was on top of the radiator and was melting a bit! So I moved it too the floor and pointed out how dangerouse it was to put it on the heater. Thankfully not long after the whole building was rewired.
hannahs radios is offline
Old 7th Aug 2019, 11:21 am   #172
Lancs Lad
Lancs Lad's Avatar
That sounds awful, Tom! I hope you pointed out to the management staff of the home how dangerous these things are.
Those chip fryers should at least have had their original fitted plugs cut off, and been fitted with nice new UK 13 amp plugs - or, better yet, hardwired into FCUs.
Best Regards,
Peter.
Lancs Lad is offline
Old 8th Sep 2019, 10:43 pm   #173
Tom williams
But wait, it gets worse!
The plugs that were supplied, were, are you ready?
EARTHED SHUCKOS with no connection to earth whatsoever and friers with a METAL case!
(Sorry for the late reply by the way)
Unfortunately I didn't get chance to tell them about the death-dapters because I wasn't there long enough to tell a member of staff
Old 8th Sep 2019, 11:39 pm   #174
Graham G3ZVT
I've had this old looking Aussie plug for a long time, I've no idea what it came off.
Name:	oz plug 3.jpg
ID:	189732 Click image for larger version
Name:	oz plug 2.jpg
ID:	189733Click image for larger version
Name:	oz plug 1.jpg
But here's an odd thing, in the middle photo, looking at the back of the plug with the earth pin at the bottom (which is the mounting convention) there is a "~" symbol embossed by the right terminal, and a "0" on the left, but according to:
https://en.wikipedia.org/wiki/AS/NZS_3112
the left terminal of the socket outlet plate is live/line/phase/active, and the right side is neutral.
Graham.
G3ZVT
Old 9th Sep 2019, 9:52 am   #175
Tractorfan
Tractorfan's Avatar
Smile Re: Any other plug collectors out there?
That's not an Australian plug. It's an Israeli one. The pins are thicker and the spacing and orientation is quite different.
https://www.plugsocketmuseum.nl/Israeli1.html
Cheers, Pete.
Tractorfan is offline
Old 9th Sep 2019, 11:24 am   #176
Graham G3ZVT
Ah!
I still don't recall aquireing the item, but at least it's a country I've been to.
I saw a couple of 15A round pin sockets in Jerusalem, no doubt a legacy from the British mandate era.
Graham.
G3ZVT
Old 9th Sep 2019, 2:46 pm   #177
bionicmerlin
bionicmerlin's Avatar
When I was an apprentice in about 1980 we used to do electrical work in a old people’s home. It had 15A and 5A sockets all over the place and no 13A sockets at all.
My boss said to me it’s only been rewired 7 years ago so that would make it 1973
I think the reason was the old people moving in were more likely to have round pin plugs on their appliances. By 1980 it was a major pain as most people moving in had 13A plugs on their things.
I have been collecting since I was a kid and when I was an apprentice one of my jobs was changing round pin plugs for square on appliances after houses had been rewired .
Hence a major boost to my collection. Andy
bionicmerlin is offline
Old 11th Sep 2019, 6:48 pm   #178
Michael Maurice
Michael Maurice's Avatar
I don’t know what the regs were in the 70’s but I’m surprised that when the home was rewired, it wasn’t mandatory to fit 13A sockets.
I do remember when my grandmothers flat was rewired, that sockets were replaced with double 13A sockets and appliances rewired, with a maximum of 12 appliances. This was in 1969.
Forum Moderator
Michael Maurice is offline
Old 11th Sep 2019, 7:00 pm   #179
julie_m
There is no limit to the actual number of sockets allowed on a ring circuit, but the floor area it serves should be smaller than 100 square metres.
BS546 is not really any less safe than BS1363, as long as the guidelines are followed. Appliances were supplied with bare wires for the user to fit their own plug well 6into the 1980s.
julie_m is offline
Old 12th Sep 2019, 5:35 pm   #180
Brigham
BS1363 is cheaper to install than BS546, which is why it was introduced.
It was a trade-off between safety and cost, nothing else.
Brigham is offline
