Old 30th Jul 2019, 7:17 pm   #1
mole42uk
mole42uk's Avatar
Default Drawing circular log scales?
I need to make a circular log scale to replace the missing one on a signal generator but I can’t find any way of generating a software based version.
Is there something I’ve missed? Can anyone help?
Richard
Index:
mole42uk is online now
Old 30th Jul 2019, 10:56 pm   #2
ionburn
ionburn's Avatar
Default Re: Drawing circular log scales?
I am not aware of software, but have not needed or looked. It is something which may be not too difficult to do by hand. You only really need the length of circle perimeter (or length of the scale if not full circle) then calculate a normal straight log scale to fit that length. Then transfer over. I can see it would be tedious but with the right tools, practical.
Hopefully someone will have done this and know the tricks (or better still - software).
One other option would be if someone were able to take an accurate photograph of such a scale from identical model.
ionburn is offline
Old 31st Jul 2019, 5:09 am   #3
Terry_VK5TM
Terry_VK5TM's Avatar
Something like this?
Done with Abacom's Front Designer, all customisable.
Change text, rotation, line lengths etc within the program.
Name:	Log scale.jpg
Terry VK5TM
https://www.vk5tm.com/
Terry_VK5TM is offline
Old 31st Jul 2019, 8:19 am   #4
kalee20
Hmmm... Can't have '0' on a log scale!
kalee20 is offline
Old 31st Jul 2019, 9:48 am   #5
mole42uk
mole42uk's Avatar
That's right. The one I have is a photocopy of an original, it reads from 10 to 100 over an arc of 290° on a diameter of 4.25" (108mm).
I want to produce a drawing so that I can send it off to have one made in etched aluminium.
Richard
Index:
Old 31st Jul 2019, 11:44 am   #6
Terry_VK5TM
Removed the 0 and changed it to 290deg scale.
Name:	Log scale.jpg
Terry VK5TM
Old 31st Jul 2019, 12:02 pm   #7
mole42uk
mole42uk's Avatar
Thank you! Please could you change it so the marks are on the inside of the arc and reverse it so that 10 is where 100 is? That would be an excellent solution!!
Richard
Index:
Old 31st Jul 2019, 12:12 pm   #8
kalee20
I've just crudely put a ruler on my monitor face and measure chord lengths: 10-20; 12-24; 20-40; 30-60; 40-80; 50-100 all measure 72mm. so the angles are the same, exactly what would be the case for a log scale!
I like it
kalee20 is offline
Old 31st Jul 2019, 1:20 pm   #9
In principle, that's correct. A real life pot will jump to zero at the end of the track, though.....
Herald1360 is online now
Old 1st Aug 2019, 4:17 am   #10
Terry_VK5TM
Household chores to finish today so I'll change it around tomorrow for you.
Do you want the arc to remain where it is and the division marks come in from there
Or
Move the arc to the outside of the division marks as they currently are?
And do you want the lines slightly thicker?
Terry VK5TM
Old 1st Aug 2019, 6:02 am   #11
Terry_VK5TM
So much for the household chores, started raining and of course it was outside chores.
Attached as first pass depending on which way round you want the changes.
Also attached as a pdf as that is nicer than the jpg's.
Name:	Log Scale2.jpg
ID:	187682   Click image for larger version
Name:	Log Scale 2a.jpg
Terry VK5TM
Old 1st Aug 2019, 3:01 pm   #12
mole42uk
mole42uk's Avatar
Hi Terry, thank you, it's looking almost right!
I attach a photo of the dial I'm trying to duplicate, I don't know why I didn't do this before....
Name:	Screenshot 2019-08-01 at 14.59.12.jpg
Richard
Index:
Old 1st Aug 2019, 3:44 pm   #13
Alf
Alf's Avatar
You might want to have a play with meterscales, I can't offer any help with the program.
Alf is offline
Old 1st Aug 2019, 5:46 pm   #14
mole42uk
mole42uk's Avatar
Thank you, unfortunately I don't have a Windows computer....
Richard
Index:
Old 2nd Aug 2019, 1:41 am   #15
Terry_VK5TM
Picture was a good idea.
I'll have a play a little later and see how close I can get it.
Are you able to measure the distance between the end of the division mark and the number and the lengths of the marks?
Terry VK5TM
Old 2nd Aug 2019, 3:00 am   #16
There are ways round operating system issues.
This Mac has Oracle Virtual Box installed. This creates a number of virtual machines and I can load any operating system I want on each machine. so I got a legit copy of XP. I can open a window on the Mac OSX screen with XP running in that window, and run windows software on it.
Radio Wrangler is online now
Old 2nd Aug 2019, 11:13 am   #17
Terry_VK5TM
This is about as close as i can get it from the picture.
Let me know if it needs any tweaks.
Terry VK5TM
Old 2nd Aug 2019, 11:37 am   #18
mole42uk
mole42uk's Avatar
Hi Terry, that is fabulous! Thank you, I'll be able to finish rebuilding the signal generator...
Richard
Index:
Old 2nd Aug 2019, 11:39 am   #19
mole42uk
mole42uk's Avatar
Hi David,
I have run Virtual Box on the Mac but I don't have a currently licensed version of any Windows system.
Richard
Index:
Old 2nd Aug 2019, 3:02 pm   #20
julie_m
If you know how to write PostScript, it would take about a screenful of code to produce a scale like that!
If you are running any Unix-like system (i.e., Mac or Linux) then you probably already have GhostScript installed, which is a suite of programs for working with PostScript files including displaying them and converting them to other formats.
julie_m is offline
