Old 9th Jul 2019, 4:46 pm   #1
Tom williams
Tom williams's Avatar
Default Brasso for cleaning vintage plug pins, safe?
Hello there,
I was just wondering if anyone on the forum has tried brasso to clean grubby and tarnished pins on vintage plugs, as I am considering it because I would think that it would shine the pins better than just using tomato sauce, if anyone has tried this, please let me know the result.
Tom
Tom williams is offline
Old 9th Jul 2019, 5:02 pm   #2
Graham G3ZVT
Graham G3ZVT's Avatar
Default Re: Brasso for cleaning vintage plug pins, safe?
Is tomato sauce better than brown sauce, and does it have to be Heinz
Brasso ought to be good, it's for cleaning brass, but is your preference the liquid or the wadding, the stuff that used to be called Duraglit?
I use Silvo wadding on Bakelite radio and telephone cases. I wonder what the difference is between Silvo & Brasso?
Graham.
G3ZVT
Graham G3ZVT is offline
Old 9th Jul 2019, 5:11 pm   #3
Tom williams
It can be any brand.
Liquid preferably
Old 9th Jul 2019, 5:26 pm   #4
Jolly 7
If very grubby, I might start with a good wash with lukewarm water followed by either Brasso with cotton wool or T Cut. Sometimes I use an ultrasonic cleaner with the plug disassembled in some lukewarm water with Fairy liquid. A couple of minutes in the cleaner usually does the trick.
Jolly 7 is offline
Old 9th Jul 2019, 5:44 pm   #5
emeritus
I use the rotary wire brush that I fitted to my bench grinder.
emeritus is offline
Old 9th Jul 2019, 9:51 pm   #6
McMurdo
McMurdo's Avatar
I've never heard of tomato sauce being used in any electrical scenario, won't it make the plug a bit sticky?
Kevin
McMurdo is offline
Old 10th Jul 2019, 8:53 am   #7
For the pins, any mechanical means of removing tarnish will be fine- Scotchbrite type pan scourer is fairly gentle but within reason you can be as rough as you like. As for polishing (why?), anything that doesn't leave a deposit will be OK.
Herald1360 is offline
Old 11th Jul 2019, 3:49 pm   #8
Mike Phelan
Mike Phelan's Avatar
Dont do this at home, but we have brass drawer handles on a dresser.
These are probably a century old, and a pal cleaned the handles in nitric acid for a few seconds; this cleaned them but they started to go black, so another wash in chromic acid made them like new; this was done decades ago and they are still bright.
Personally, I wouldn't polish plug pins. Coca-Cola is good for cleaning brass - I believe some folk actually drink it!
Mike.
Mike Phelan is offline
Old 11th Jul 2019, 4:03 pm   #9
stevehertz
stevehertz's Avatar
I use abrasive rubber blocks where access is not a problem. Otherwise Brasso liquid or wadding, or Solvol Autosol. If the tarnish is not bad, then spray on switch cleaner. The latter will probably ensure a good electrical contact where the previous ones will also look shiny albeit more difficult to achieve.
stevehertz is online now
Old 13th Jul 2019, 11:08 am   #10
rontech
It is the acetic acid in sauces etc which is a weak acid and slowly dissolves a very small amount of metal / oxide.It is safe to use.
I use the distilled white variety of vinegar, the quite cheap Tesco basics stuff. Add a very small drop of detergent. May used in conjuction with scotchbrite for the more resistant items.
Time flies like an arrow, fruit flies like a banana
rontech is offline
Old 13th Jul 2019, 11:57 am   #11
ex seismic
'The Repair Shop' clock man uses some magic wonder fluid from the clock repair world which makes brass bits come up like new without scrubbing.
ex seismic is offline
Old 13th Jul 2019, 12:21 pm   #12
OldTechFan96
OldTechFan96's Avatar
A rotary tool along with wire brush and polishing wheel attachments will get things looking brand new. A selection of polishing compounds will also come in handy.
OldTechFan96 is offline
Old 14th Jul 2019, 7:34 am   #13
Radio1950
Hi Tom
My personal experience is that old formula Brasso is excellent for cleaning brass 1/4 inch telephone plugs.
Clean residue off with metho.
Here's my can of 1960s Brasso for memory lane walkers.
We used a lot of this.
We went metric in 1966 in Australia.
Name:	1 Brasso Aus 1966ca DSC07683.jpg
ID:	186646   Click image for larger version
Name:	2 Aus Brasso 1966ca DSC07682.jpg
Radio1950 is offline
Old 14th Jul 2019, 1:17 pm   #14
Mike Phelan
Horolene or similar (QV).
Mike.
