Old 9th Jul 2019, 7:15 pm   #1
Christinemacca
Default Auto return too soon on turntable?
Hi folks. Could some please help me??
I've a Sanyo g2711 model, and all seems fine apart from when I'm playing a record, it stops about 15-20 seconds before the song is finished. I'm kinda clueless about things like this. I adjusted the anti skate incase this was the problem, but it didn't help.
Does anyone has any suggestions how to fix things without opening anything up?
Many thanks
Christine
Christinemacca is offline
Old 9th Jul 2019, 7:34 pm   #2
'LIVEWIRE?'
'LIVEWIRE?''s Avatar
Default Re: Auto return too soon on turntable?
At the very least the turntable will have to be removed. If, as many japanese decks, do, this has a Cam Gear and Trip Pawl, the likely cause will be dried grease.
'LIVEWIRE?' is offline
Old 9th Jul 2019, 7:55 pm   #3
Christinemacca
Thanks so much for your quick reply. I can manage as much as taking the turntable off, as I changed the belt. Much more than that I'm rubbish at this kind of thing. I suppose I can live with this if it's a difficult job. Thanks again.
Old 9th Jul 2019, 9:24 pm   #4
'LIVEWIRE?'
It's not a difficult job. I'm not familiar with the Sanyo Turntable in particular, but the cam gear is usually clearly visible once the turntable is removed-it's usually a white plastic gear around 2" in diameter. The trip Pawl is two metal pieces which must be free to move. Maybe another member can explain in detail what is needed, but essentially the old grease should be cleaned off and new lubricant sparingly applied.
Old 10th Jul 2019, 9:31 am   #5
This thread describes how the trip pawl works:-
https://www.vintage-radio.net/forum/...ead.php?t=8936
Station X is online now
Old 10th Jul 2019, 12:57 pm   #6
Techman
Techman's Avatar
No, you can't just live with it.
When the chunk of metal on the platter spindle comes into hard contact with the trip as the stylus traverses the run out groove on the record, a considerable jolt is transferred to the stylus for a fraction of a second. This doesn't matter in the run out groove, but will matter if it keeps happening in the same place on the delicate playing grooves of an LP record. If you turn the volume right down and listen very carefully to the record deck, you'll probably be able to hear the clonk, clonk, clonk on every revolution of the record just before it auto-trips and lifts the arm off. If you look very closely, you may even be able to see the pickup head move or jump very slightly with each 'clonk'!
You risk spoiling your records (as well as spoiling your enjoyment of them), so it needs fixing. As said, it's an easy enough job.
Techman is offline
Old 10th Jul 2019, 8:39 pm   #7
Christinemacca
Thanks very much
Thanks I appreciate this
Thank you. I appreciate your advice
