Old 26th Apr 2019, 1:26 am   #1
Redders03
Default Marconi TF2370 110MHz Spectrum Analyser Interconnection Cables
I've recently purchased a Marconi TF2370 and discovered it's missing the interconnection cables between the display unit and attenuator box.
Does anyone have a set spare, or know where to source ?
Thanks
Alex
Redders03 is offline
Old 26th Apr 2019, 12:39 pm   #2
woodchips
Default Re: Marconi TF2370 110MHz Spectrum Analyser Interconnection Cables
Can you post a photo of the connectors please.
From memory they are the Centronics type, 50 way? but quite short and 90 degrees.
woodchips is offline
Old 26th Apr 2019, 12:50 pm   #3
Redders03
Hi Woodchips,
Yes, they are Centronics 50 Way. I've provided images from my unit and the diagram from the manual.
ID:	181882   Click image for larger version
ID:	181883   Click image for larger version
Alex
Old 26th Apr 2019, 12:58 pm   #4
"Amphenols". THe male connector is wedge-shaped. Quite a lot of firms used them, not just Centronics, and Amphenol made plenty of other connectors. A search fro Amphenol, 50 way might find some.
Radio Wrangler is online now
Old 26th Apr 2019, 1:24 pm   #5
Redders03
David, just discovered the Amphenol / Centronics (50 Way) was previously used as a connector for SCSI 1 :
https://www.cablestogo.com/learning/...#centronics-50
Therefor its not impossible to find such cables when searching for SCSI 50 Way:
https://www.ebay.co.uk/itm/SCSI-cabl...wAAOSw~KpceY8R
I'm hoping this to be suitable ?
Alex
Old 26th Apr 2019, 1:46 pm   #6
I've never used SCSI, but if that's a 50 way amphenol, then you ought to be able to get the core of the connectors quite easily.
The next problem is finding out how they're wired. If frequency references, signals, etc make the trip there may be some shielded coaxes and twisted pairs involved.
I don't know my way round these analysers specifically... I designed such things for the other brand...
Old 27th Apr 2019, 7:13 am   #7
Diabolical Artificer
Diabolical Artificer's Avatar
Bummer, that's really unfortunate, here's a pic of the connectors. I had one of these SA's Alex and am pretty sure each lead is wired different, an A and a B lead if you will.
Andy.
Name:	Screenshot from 2019-04-27 07-10-27.jpg
Old 28th Apr 2019, 4:37 pm   #8
Redders03
Thanks to everybody who added to this thread
Guess i'll have to make the cables up, rather than source originals.
Once I get round to finding a solution, i'll post about it in the Test Equipment forum.
Mods, feel free to close this at your discretion.
Alex
Old 28th Apr 2019, 9:54 pm   #9
g4wim_tim
I think I may have a service manual for a 2370 hidden away in the loft - can't count on it, but would it be of any use ?
Building and tinkering for over 50 years, from 807's to digital amateur TV.
g4wim_tim is offline
Old 28th Apr 2019, 10:19 pm   #10
PJL
You can download the manual from Bama. I have one which I managed to get sort of running. I also bought a low loss probe for it which I have yet to try.
The main problems are the PCB's you need an extension board for and lots of unreliable 'Griplets' that need soldering.
Mine still has a slightly high noise floor and the switches need to be cleaned.
PJL is online now
Old 28th Apr 2019, 11:33 pm   #11
Redders03
If you do have an original copy, I'd love to add it to the collection. I'm in no rush for it either as I won't be looking at this till next month.
Yes i've read about the 'Griplets', I don't mind spending summer on it while I have some spare time.
Also, a seller on eBay makes custom extender cards, I'll give them a try if needed.
Alex
Old 7th May 2019, 5:10 pm   #12
Redders03
For anyone in the future looking for such cables. I found an appropriate set of SCSI 1 Cables by IBM.
Sourced here :
https://rover.ebay.com/rover/0/0/0?m...2F391907391941
These crucially include 50 Cores with 1-1 mapping for each pin.
0.6M in length, so particularly useful while troubleshooting.
I can’t comment on side affects of not including coax, like the originals at this stage. My own unit requires attention. However on the Marconi Yahoo Group members have vouched using 0.6m cables should not pose an issue.
Alex
Old 8th May 2019, 11:52 am   #13
Redders03
I’ve been informed by the Marconi Group the following also work as a substitute:
Farnell 152-5882
https://uk.farnell.com/videk/1501/le...ngdom%2Fsearch
Mods feel free to close this thread.
Sourced here :
Alex
Old 8th May 2019, 1:05 pm   #14
peter_scott
peter_scott's Avatar
I got around the extender card problem by temporarily soldering a short extension wire onto points that I needed to monitor.
Peter.
peter_scott is online now
Old 19th May 2019, 7:05 pm   #15
Sean Williams
Sean Williams's Avatar
if you are still interested, I picked up one of these cables today at the Luton Radio Rally - Yours if you want it
Sean Williams is offline
