3rd Apr 2019, 1:59 pm | #1 |
Storing / Sorting Resistors?
I'm finally biting the bullet and populating two component draw units, one for Capacitors one for resistors. I have a third large unit for various other bits that I have much less quantities of.
Currently I have them all mixed up and it drives me nuts trying to find what I want, I waste more time assembling parts for a project than actually building it So, I have 40 drawers for resistors. Any advice on methods of sorting? I plan to have them in labelled bags inside the drawers, just can't seem to decide a way that makes sense. I considered ranges, I.E < 100 ohms, < 1k, < 100k etc . Just curious what others here do |
3rd Apr 2019, 2:04 pm | #2 |
Re: Storing / Sorting Resistors?
I sort mine by the multiplier colour, e.g. all reds, all greens etc. It doesn't usually take that long to find the one you want unless it doesn't exist, then you spend ages hunting for it.
3rd Apr 2019, 2:28 pm | #3 |
I have each drawer for resistors cover a range of E12/24/48 etc. So 390-430 ohms for example.
Then I have to use a magnifying glass and meter just to confirm which one to use if I have multiple values in that range. Capacitors, values pF to 1uF non-elecrolytic are in sorter trays. For electrolytic there is such a massive range of physical sizes from tiny to huge; I'd welcome any idea how to logically organise those! Craig |
3rd Apr 2019, 3:40 pm | #4 |
I use one drawer per base value, so 56Ω, 560Ω, 5.6kΩ, 56kΩ, 560kΩ, 5.6MΩ share the same drawer. Six different values per drawer is manageable.
Capacitors though I group in value bands, thus 1 - 1.5nF, 1.8 - 2.2nF, 2.7 - 3.3nF, 3.9 - 4.7nF, 5.6 - 6.8nF, 8.2 - 10nF. Three values per drawer. Needs more drawers to go from 10pF to 10μF of course. But it works well. |
3rd Apr 2019, 3:59 pm | #5 |
I have 3 sets of organisation for my resistors:
An ex-WD drab olive drawer unit for vintage resistors (probably all dud!) A multi-drawer unit with each drawer only about 1.25" square - starting 1 on the left, 10 below it etc 2 shoe boxes with envelopes in each "low" values in one box, "high" values in the other. 10k as the division. I use the shoe boxes far and away more than the others. Any values can be slipped in in the correct place. Wattages can be mixed within reason. Immediately obvious when a value runs out. And 2 shoe boxes is quite a small volume. Envelopes are just SAEs from companies. Other resistors like vitreous enamel ones are small in number and just have a box of the right size. Not so organised with caps... Graham
Half my stuff is junk - trouble is, I don't know which half! |
3rd Apr 2019, 6:31 pm | #6 |
I use one row for multiplier - x1, x10 and so on. Then each column is for value - 1.0, 1.2, 1.8 in the first, 2.2, 2.7, 3.3 in the second - oh, you get the idea! Depending on the size of each resistor, each drawer could be subdivided if you like. I use the remaining rows for specials like fusibles, wirewounds and so on.
Capacitors - much the same idea. Much easier to see when you're running out of stock. Amazing how few resistors I use in day to day repairs now. I actually used one today but it must be well over a week since I used one before that. Years ago I'd be using several a day and far fewer capacitors. |
3rd Apr 2019, 6:49 pm | #7 |
A little while back I decided to make use of a stack of old Chinese Takeaway plastic tubs to sort my resistors into one (preferred) value per tub. I say preferred value, as (unless I have a large number of them) I put non-preferred value ones in with the nearest preferred.
Yes, it does take a large number of tubs, and I didn't initially have quite enough, despite having amassed quite a collection over the years, but an appeal to colleagues for their used tubs, combined with eating a few more takeaways myself, and I got there. The beauty is that I have an old cupboard into which the fit nicely.
3rd Apr 2019, 7:35 pm | #8 |
I don't know if it's still the case, but Screwfix had some nice 5-wide by 10-tall drawer units at a very good price. I bought one for my resistor stock.
Colin. Yes, they do still have them: https://www.screwfix.com/p/50-drawer...age-unit/5616p £24.99 inc. VAT. Last edited by ColinTheAmpMan1; 3rd Apr 2019 at 7:40 pm. Reason: URL of drawer unit. |
3rd Apr 2019, 7:46 pm | #9 |
I have two of those in my shed for screws, washers and nuts. They are a bargain for a metal framed unit. Mine stand on the floor, not screwed to a wall, and they are heavy enough not to tip over when pulling drawers out.
Craig |
4th Apr 2019, 5:45 pm | #10 |
I've gone for three stacked 5 wide by 4 high drawer units for 10-100K decades of E12. Other values (oddballs, E24 and above specifics etc) get another 5 wide by 4 high rack with ranges of values for each decade.
Wirewound and power resistors just get one larger drawer per decade plus another random drawer of "MISC WATTY Rs". Capacitors largely lurk in E3 labelled (1, 2.2, 4.7) drawers with any intermediate values in the lower value drawer. Big electrolytics are somewhat randomly scattered!
8th Apr 2019, 9:42 pm | #11 |
I can't be doing with keeping resistor series in those little plastic drawers with the dividers, because the capacity is inflexible, and dropping them is a disaster. I prefer to keep separate values each in its own bag which can be leant up in sequence in a box. Those zip-seal poly bags are good while they are young and you can really stuff them full if needed. The Stores Dept. in one factory would issue kits for production in "Crystal Bags", which I think were formerly used for payments to 'weekly' workers. You can write on them and they are semi-opaque so you could see how many, if not what, was inside.
- Julian It's good here |
8th Apr 2019, 9:43 pm | #12 |
Speaking of storing small quantities of small things in small boxes, I wish I could find a supply of lightweight, unprinted plain card boxes. To buy in small quantities they would have to pack flat and simply push together. What's frustrating is that almost everything you buy now comes in such a box.
The smaller sizes you need for Rs, Cs and semicons in individual types can be found in those clever little card boxes for sweets which have an ingenious but effective closure mechanism (cardboard engineering). You can probably realise a more plentiful supply for E12 or E24 series parts by recruiting older friends to save boxes for statins and heart-pills, which tend to be similar sizes and can be packed on end. The Stores Dept. where I worked kept small components in folded and stapled plain card boxes, similar to those used for MOD spare parts issue. We sometimes also used clear plastic jewel cases. Searching and eBaying for small plain boxes you'd think they didn't exist, but every 'thing' you buy comes in one! The next size up commonly found is the light-bulb box, which is a convenient size for things like pots and switches, but unfortunately they open at the top, not along the long side. Can't bulb manufacturers be persuaded to make a slight change in their packaging
8th Apr 2019, 10:08 pm | #13 |
This method works for me, 8 rows of draws for values .1 .22 .33 .47 .68 and multiples of 10 in the other rows. It more or less works for capacitors as well for me.
Mike |
8th Apr 2019, 10:44 pm | #14 |
i have 2 values per drawer, with a divider. So, we get 10/12R, 15/18R, 22/27R etc like that.
As values are becoming more esoteric, I bundle those into old chinese takeaway tubs. For example last week I had to order some 90.9 ohm 1/4w resistors and 10 was the minimum.
Kevin |
9th Apr 2019, 12:34 am | #15 |
Drawers take up too much space. I am using wham boxes (from homebase) + 3.5x4.5" ziplock bags from bluestar(uk) on ebay:
Got 12 boxes with all my parts in. Depicted is the discrete semiconductors box. |
9th Apr 2019, 6:00 am | #16 | |
Assuming they might still be available, auto parts stores may be happy for you to take away the empty boxes. |
5th Jan 2020, 5:52 pm | #17 |
A group I am in was today presented each with a little box of the type I have been seeking. Our leader got them from Amazon by searching for "wedding favour boxes".
Checking there I see 5cm cube boxes in white can be had for £8 per 50 which makes them 16p ea and slightly more than I hoped to pay. They are thin card but suitable for screws and the like. On eBay I can find some with lower (and much higher) prices, they are also called Ballotin boxes, but the Amazon ones come ready-glued which is better. They come packed flat and are assembled by pressing the base flaps into each other in the correct sequence. Maybe I'll wait til I've used up the large stock of statin and heart-pill boxes which have accumulated over the years
5th Jan 2020, 6:45 pm | #18 |
To store 1000 one watt resistors in 100 values I stapled together, in tens, 100 press & seal grip bags with write on panel (89x114 mm).
At present these are in a box about 16x10x11 cm but could perhaps go in drawers depending on the size of the bags and drawers. David |
5th Jan 2020, 6:47 pm | #19 |
I have about 200 plus 2 ounce tobacco tin (remember them)in two a home made wooden racks, in which I stored nuts, bolts, washers, and screws imp / metric/BA. A few years ago I was given a special suitcase supplied by RS, which contains about 70, one inch diameter clear plastic tubes all filled with a large range of resistors.
8th Jan 2020, 2:37 pm | #20 |
I have quite a lot of drawers of the type Crackle illustrates in post #13.
I dont use them for all small components, as some transistors etc. are in multiple quantities in plastic resealable bags. The problem is that just a small bit of one of the bags protrding above the top of the draw level can, and often does, result in the draw sticking when opening it. Has anybody found any of these draws with flat lids to stop this happening? I had just one once, - in a pile of bits that I bought. All my considerable stock of small resistors are in many small cardboard boxes (ex Thorn electronics) of around 1960s vintage, boxed generally by E24 values, or nearest above the particular resistor. The boxes are wearing well in spite of their age, and stand on a shelf above the bench. Tony. |
