UK Vintage Radio Repair and Restoration Discussion Forum
UK Vintage Radio Repair and Restoration Discussion Forum (https://www.vintage-radio.net/forum/index.php)
-   Vintage Test Gear and Workshop Equipment (https://www.vintage-radio.net/forum/forumdisplay.php?f=36)
-   -   Coultant power supply connections ? (https://www.vintage-radio.net/forum/showthread.php?t=179560)
dragonser 30th Apr 2021 2:53 pm
1 Attachment(s)
while going through some bits I found this Coultant power supply.
powered it up ( which I probably shouldn't have done ) and it still works...
+ 15 and - 15v rails ok.
so is the 5 volt supply on the yellow and black sockets...
But does anyone know of a better way of connecting the mains to it ?
would some crimps be a safer way ?
Refugee 30th Apr 2021 3:08 pm
Re: Coultant power supply connections ?
You can still get those crimp tags like the ones on the yellow wire.
There is a spare fixing hole that could be used to fit a finger guard.
barrymagrec 30th Apr 2021 3:09 pm
Small (6ba?) ring crimps. There may have once been a paxolin cover over the teminals, there certainly should be something.
Something to remember on old Coutant supplies is that different models sometimes have mains and output terminals at different ends of the terminal strip so if you are using several different units mistakes can occur. I don`t need to tell you how I discovered that.
Cobaltblue 30th Apr 2021 3:28 pm
1 Attachment(s)
We normally used these with a fanning strip and a cover.
The fanning strip ensured that you didn't get the wiring wrong (unless the spare was a different manufacturer of course)
Mike T
Orakle42 30th Apr 2021 3:46 pm
I suspect that the Yellow & Black sockets are just monitoring points for the 2 supply rails.
Why do you think there should be a 5v rail?
Some of these Coutant supplies also had remote sensing terminals but this one does not.
Most of these were 1 or 2 rail systems ranging from 1 to 10 amps capacity with series regulators.
Popular in the early sixties and used widely in the computer industry.
Orakle42
Orakle42 30th Apr 2021 4:11 pm
4 Attachment(s)
Further to my previous reply, you may find the attached of use, however, the document does apply to what I suspect is a later model,
Orakle42.
