Bush TV 22 no line output voltage
I now have my father's Bush TV22, it was bought new in 1953 and only used for a few hours a night for around 12 months when he was diagnosed with TB, my mother put the set into storage in the attic where it has remained for the last 63 years and it is in pristine condition, all valves are lit including the tube, tuner and amplifier appear to be working OK, but no EHT to the side of the tube, can any one help as I would really like to be able to use this with a video or something else, if this was a valve amplifier I would be able to fix the problem but never worked on valve TV. Howard.
Re: Bush TV 22 no line output voltage
Hi You will need a standards converter to operate this set as it is 405 line.
The most probable cause of your problem is leaky or shorted wax capacitors. They will all need changing for reliable results. There are a couple that are easily missed behind the tag board if I remember correctly. Regards Rich. |
Also any hint of damp in the LOPT will upset EHT generation. There's plenty of advice on the forum about how to dry it out.
If there is no EHT, take a look at the EHT rectifier valve, it's tacked on the side of the line output transformer, make sure it's connections are good, and see if you can see the heater lighting in the valve. The heater for this valve is powered by the winding on the top of the transformer, check this for continuity, which will only be a few ohms. If the line output stage isn't running well (because of leaky caps or damp transformer, as mentioned above) then there may not be enough power to heat the EHT rectifier, which will stop any EHT reaching the tube.
Regards, Lloyd. |
How have you determined that there is definately no EHT? Can you hear a line whistle?
Silent no whistle, also rectifier valve on side of line output transformer is not lighting up, Howard.
Hi there, I am in the middle of restoring my TV22, I have had 2 transformers re wound,
(line osc etc) and replaced almost all capacitors, as 90% were dud It wasn't a difficult job, and also found lots of resistors faulty. I would advise you change the caps one by one. If the line output tramsformer has gone, it can be re wound, but I think you should replace the caps as the previous replies suggest. No line could be one , of many faults. PM me if you get stuck as Im on the same learning curve!! Lots of info about this set available. Good Luck Richard. |
Thanks to every one for the info, Regards Howard.
If you're going to replace the wax caps in stages with power-ups in between, it would be a good idea to prioritise the four or so caps connected across the heater chain. If any of these fails short-circuit it could stress or burn out a few valve filaments.
The grid coupling cap to the line output valve should also be prioritised for the sake of the LOPT. This is the advice I was given when restoring my TV22. Edit - Which model TV22 is yours by the way? The service information differs between the Mk 1 and Mk 2, and the latter also had a couple of subtypes. I think the Mk 2 may have been introduced sometime in 1953 so yours could possibly be either. Liam |
How can i tell if it is a mk1 or 2 ?, Howard.
If I remember right, the Mk 1 has EF91 valves on the RF deck, and the Mk 2 has EF80's. Also the CRT, in the Mk 1 it will be a Mullard MW22-18, and the Mk 2 will be a Mullard MW22-16 with ion trap magnet.
Just to add to this, there was also a model TV22 A, which is completely different to the above! If it's a TV22 A it will say on the back. Best way is to take a picture of the inside and post it here, one of us will be able to identify it. Regards, Lloyd. |
This page has a lot of information on line output and EHT problems which may be useful: http://www.oldtellys.co.uk/otltbeht.html
Liam |
1 Attachment(s)
Here is some data I collated for the TV22/24 Mk I and II. It states Mk II in the document, but the LOPT electrical characteristics for Mk I and Mk II models are the same. However as already stated, I can confirm that the TV22A/TV24A have completely different LOPTs.
Hope someone finds the info useful. Ian |
Thanks for that info, it is a MK2, Howard.
