Manor Supplies Mk5 Colour Pattern Generator
With reference to this old thread https://www.vintage-radio.net/forum/...ad.php?t=20752 I was wondering if anyone has a decent copy of the Manor Supplies Mk5 colour pattern generator circuit diagram. The original diagram is rather difficult to read. Thanks. Regards, Symon |
Re: Manor Supplies Mk5 Colour Pattern Generator
I think I can read that enough to start work on a new replacement drawing for you – I'll get it started this weekend!
Chris Williams |
The version posted by kevinmin later in the thread looks pretty readable.
Thanks Chris, that's very kind of you but don't waste too much of your time on my account. I'm mainly looking to confirm the component references/values on the circuit diagram. If you do decide to redraw it I would be most grateful. I had started to try and redraw it but I'm finding it very difficult to read many of the component references and values. The components list does help to give a few clues though. Many of the references are just a blur on the circuit. I opened the file in MS Paint and used the eraser to remove all references/values etc. The initial idea was to print out the circuit and hand write the refs/values as a rough but clear copy then use say KiCAD to reproduce a decent circuit diagram. Even the IC pin names/numbers are very hard to discern. It is doable but quite a challenge and time consuming. Thanks. Regards, Symon |
Yes, the circuit provided by kevinmin is considerably clearer than the earlier copy in that thread but it is still difficult to discern many of the characters. It would appear that is the best available so it looks like I'll try to redraw it. Chris also kindly offered to help as well. Regards, Symon |
As I said, I think I can decipher most of it!
A member did offer a Mk V. un–tested a while back and I made an offer for it as I wanted it for the purpose of redrawing all the documents but it had already gone! Chris Williams |
