Capacitor coding help please
2 Attachment(s)
Morning all and happy new year. My daughter's record player, which only identifies itself as an ALBA solid state, has started to distort a bit during play. A look inside shows a suspect looking disc capacitor, but I'm not familiar with the colour coding. It just appears to be brown with a single orange stripe across. Could someone look at the photos attached and identify it for me please?
Re: Capacitor coding help please
Thermistor, you might find the data on the electrojumble website:
http://www.electrojumble.org/techdata.htm Lawrence. |
Thanks Lawrence. It appears to be a Mullard VA1040.
It is a resistor whose resistance varies with temperature. It is probably used to set the bias for the output transistors. If it has become faulty then distortion is quite likely. Why do you suspect that component?
EDIT: Post crossed. Lawrence. |
The thermistor does not look that bad.
I would first make sure that the stylus is OK first. What tools have you got? |
I've cleaned the pots and put a new stylus on. I thought the thermistor looked a bit crusty around the edges, so it might have deteriorated a bit.
It sounds like a biasing problem in the output stage or thermal runaway due to leakage in one or both of those output transistors in the copper heatsinks. The adjustment pot on the circuit board should not be adjusted unless you know what you're doing. The pot itself could have a dodgy contact, but any cleaning or replacement would mean careful readjustment with a test meter and service information. There's other possible causes of the distortion that you mention, but saying exactly what it could be is really only guessing, and that's never a good idea if you're a novice.
I meant that I've cleaned the volume and tone pots. I've only worked on valve amps before - usually replacing the capacitors in the can seems to work for them.
