ZENITH console radio 8S661
Hi everyone
I have got hold of a Zenith console radio 8S661 which has had some partial restoration so works very well on radio reception. I would like to add an auxiliary input as there is no gram on these, my thoughts were via the volume pot but wonder if anyone could advise the best way, I would need to cut the radio signal as its too noisy even on one of the quieter wavebands. |
Re: ZENITH console radio 8S661
I would use a mono jack socket of the switching type. There are types with 2 or more change over contacts which give you a number of options including breaking the audio path from the detector and changing the DC conditions in the local oscillator so that it doesn't run.
I have seen some folks adding a switching jack at the grid of the first audio tube, or first audio amp xistor.
