UK Vintage Radio Repair and Restoration Discussion Forum
UK Vintage Radio Repair and Restoration Discussion Forum (https://www.vintage-radio.net/forum/index.php)
-   Vintage Television and Video (https://www.vintage-radio.net/forum/forumdisplay.php?f=37)
-   -   Panasonic NV-HV60 VCR (https://www.vintage-radio.net/forum/showthread.php?t=159175)
Vectamart 24th Aug 2019 5:08 pm
I bought this machine new about 15 years ago and had been using it on a regular basis until one day, it went dead with a cassette stuck in it.
This afternoon, I decided to take a look at it; alas, it was not going to be straightforward as I do not have a service manual for this model. I spotted a 1000mfd/10-volt capacitor in the power supply that had a distinct bulge in its can so decided to replace it. I then discovered that in order to remove the printed circuit board, I first needed to remove the stuck cassette as two of the screws securing the board were beneath the deck.
Anyway, I replaced the offending capacitor but the machine is still dead. The display is not illuminated and there is no response from any of the controls.
So - is there anyone out there who can offer any suggestions? Many thanks in anticipation.
dj_fivos_sak 25th Aug 2019 2:23 am
Re: Panasonic NV-HV60 VCR
Did you look for blown fuses in the PSU? Do you have an ESR meter to measure the caps?
Vectamart 25th Aug 2019 9:17 am
The mains fuse is intact. Power is getting as far as the 33mfd smoothing capacitor, which has tested ok. The fault appears to be somewhere in the SMPS. However, as I do not have a circuit diagram I am now a bit stuck. I was hoping that someone may have some experience of this model and its stock faults.
vhs doctor 25th Aug 2019 9:56 am
Hi
Check this
https://elektrotanya.com/panasonic_n.../download.html
jjl 25th Aug 2019 1:03 pm
A possibility would be an open circuit startup resistor. This is a very common fault with switch mode power supplies in all sorts of equipment. There is a thread that mentions this problem in a Panasonic VCR here
https://www.vintage-radio.net/forum/...d.php?t=158211
John
gallowfields 25th Aug 2019 7:35 pm
hi, most panasonic vcr,s have a 1uf 63v in the primary of the smps which dries up we used to replace these with 1uf 100v 105degree types
Red to black 25th Aug 2019 7:52 pm
Check R1150 and R1154 both 1 meg resistors, these are the two start up resistors for this machine, one or other usually goes either O/C or high resistance.
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
Copyright ©2002 - 2020, Paul Stenning.
