Ultra 6820
1 Attachment(s)
My ultra 6820 displays a single line. When I looked inside I noticed the lopt was making this funny noise that sounded like the whistle of a kettle. |
Re: Ultra 6820
First move, check C89 1uf. This is the decoupling capacitor on the boost HT line supply to the line oscillator. J
Re: Ultra 6820
Hi Ryan
Good to hear from you again. Is this 1500 chassis if so a common fault causing the white line is that one of the tags on the frame output transformer as broken from the printed circuit. Look at the top right side of the chassis the transformer is in the corner resolder all the pins. The whishle is possible a different fault as John says try the cap but it might be just a loose winding on the loptx or a another coil possible line lin in any case should not be to big a problem regards Derrick Ps My door is still open regarding your Bush 191 |
Re: Ultra 6820
Thank you for your responses
The whistle coming from lopt has stopped now and now I can just hear the normal line whistle that you usually hear. I can hear arcing coming from the anode cap when it is connected to the crt the arcing is only faint but I just thought I'd mention it just in case. Derrick I shall re-solder the transformer when I get my new soldering iron, my current one won't heat up for some reason... :( Kind regards, Ryan |
Re: Ultra 6820
Nice set. Seeing there's a horizontal white line this clearly suggests the line timebase is functioning. Slight lack of width evident on the left which could be due to the feed resistor to the width control changing value. It's a good idea to check the boost volts as if high can seriously shorten the life of the EHT tray. If lack of width persists with the boost voltage correct suspect the scan correction capacitor.
With the frame collapse problem I agree with the comments re checking the panel close to the frame output transformer. Presumably you've tried a new PCL85/805? What are the voltages around the PCL85/805? Cheers, Brian |
Re: Ultra 6820
Hi Brian,
I managed to sort the lack of width that was due to the pots at the back. I have tried a new PCL805 but it hasn't made a difference, I'll get back to you with the voltages. Kind regards. Ryan |
Re: Ultra 6820
Hello,
There are two 18k 0.5W carbon resistors in the feedback circuit from the (pentode) anode of the PCL805. They can go o/c. Worth checking. Regards, Dazzlevision |
