Ekco PT378
Hi Guys
I'm completely new to this so please bear with me. I recently found an old Ekco radio that is of sentimental value to my wife. Here I must admit to being completely technically illiterate regards electronic etc. It appears to be in order though it looks a bit grubby. I think it may even work if I can find a battery (9v I think) Does anyone know of an individual or outfit that can have a look at it and get it going. I'd be happy to clean it and polish it myself but the electronics are a black art as far as i am concerned. I live in S Wales but could get it posted if necessary. Thanks Pav |
Re: Ekco PT378
The battery is a PP7 9 volt and are available online, it may be possible to make up a 9 volt battery with AAA cells. If the radio as not been damaged it may well work ok with just a new battery.
Re: Ekco PT378
A Poundland PP3 (the size used in smoke alarms) has the right voltage, though you will have to make up a connector. Make sure you connect the battery with the correct polarity if you do this. A PP3 has lower capacity than a PP7 so won't last as long, but is much cheaper and will be fine for occasional use.
Re: Ekco PT378
Hi Guys
Thanks for the replies. I have tried putting a 9v battery in but nothing I'm afraid. Given this I am down to asking for suggestions as to where or who to send it to to have a look at it and get it going. I don't think it would be an awkward job as all the bits are there. Any suggestions guys? Thanks AG |
Re: Ekco PT378
The great advantage of a radio like this is that it can easily be posted to a repairer. |
