UK Vintage Radio Repair and Restoration Discussion Forum
UK Vintage Radio Repair and Restoration Discussion Forum (https://www.vintage-radio.net/forum/index.php)
-   Vintage Radio (domestic) (https://www.vintage-radio.net/forum/forumdisplay.php?f=20)
-   -   Help to ID this chassis and valves (https://www.vintage-radio.net/forum/showthread.php?t=136513)
Otari5050 14th May 2017 8:20 am
3 Attachment(s)
Hi folks,
Picked up a Gulbransen desk-top radio-gram but it's missing the ID info off the back.
Also missing two tubes, which so far I believe are a type 80 rectifier and possibly a 2A5 output.
I'd like to ID the chassis so I can find a diagram for it and work out what the tube complement is, as only one has a number on it (the others have worn off) and that's the one in the centre at the rear which is a type 85.
Yarraman 14th May 2017 9:47 am
Re: Help to ID this chassis and valves
If one of the tubes is an 85 then the radio must run on 6.3 volt tubes, so i would expect the output to be a 42 with an 80 rectifier. The others could be 6A7 convertor and possibly a 78 or 6D6 IF amp. Most of the schematics for these are all very similar.
short wave 14th May 2017 11:30 am
Any chance of a front photo as well? thanks
Otari5050 15th May 2017 10:16 am
1 Attachment(s)
Here it is in all its resplendent glory ;)
