Identity help!
I'm new to the forums but have lurked on here for a few years! Hope someone can help with this... I'm in the process of refurbing/fault finding a 'gram I picked up a few months ago. It is an Ilse Tonmobel cabinet, Collardo record deck but the Blue Spot/Blaupunkt receiver I'm struggling to identify? Have a model number etc but no name. I'm looking for schematic to aid repairs so any hints as to what the set is would be appreciated!:) |
Re: Identity help!
Pictures would help.
Re: Identity help!
2 Attachment(s)
This time with pics...
Re: Identity help!
You will probably find the Blaupunkt chassis was used in a number of more mainstream radiograms.
Interesting thing - I've never seen a cabinet like that before. |
Re: Identity help!
That's a COLLARO RC456 autochanger which would date it to late 1956 or 1957.
Re: Identity help!
Here's a selection that might use the same or similar chassis:
https://www.doctsf.com/grandlivre/pr...ubmit2=Valider You might be able to narrow it down by the valve line up. Lawrence. |
Re: Identity help!
Just fault finding at the moment, have output but a bit distorted-hence looking for model/schematic. |
Re: Identity help!
I have what looks like (from the front) a Blaupunkt radio that uses the same chassis. Unfortunately it is currently packed away so I don't think I can get at it to find the model number. When I last had it working it sounded very good.
Re: Identity help!
David |
Re: Identity help!
What is the valve line up?
Re:Identity help!
5 Attachment(s)
Re: Identity help!
Before running for too long a period and with distortion present it would be advisable to change thr output valve grid coupling capacitors
Ed |
Re: Identity help!
Thanks-Yes I’ve swapped out capacitors already and have output valve coming in the post!
Hopefully gets it up and running. |
Re: Identity help!
Lawrence. |
Re: Identity help!
That’s great thanks for your help! |
Re: Identity help!
Thanks to Lawrence identifying the set I've been able to cross reference that with the Radiomuseum listings for the cabinet manufacturer and came up with a match.
https://www.radiomuseum.org/r/ilse_charmaine_r66.html Thanks again! :) |
Re: Identity help!
No problem.
Lawrence. |
