Unknown Cossor Valve Radio. Identified as a Cossor 533A.
Hello,
I am having problems trying to identify a Cossor Valve Radio. It is quite a large model, say desktop size and appears from my lay observations to have 5 valves. This is mains powered and has no back on it. The tuning knob is on the side of the case. The front has a Cossor metal label. Other than that no indetifying model number. Please refer to the pics to aid identification. I have reviewed all of the listed Cossor models on the radio museum website but cannot find a match. That isn't to say I may have missed something. Thanks in advance for your consideration. |
Re: Unknown Cossor Valve Radio
1 Attachment(s)
Well you didn't try the Cossor Webs site.
http://www.cossor.co.uk/rogues-gallary With that very loose description it could be a 533A Cheers Mike T |
5 Attachment(s)
Sorry forgot the pics!
Apologies! |
Thanks
I'll review that website right now |
Pretty certain that is indeed a 533A
Cheers Mike T |
Thanks Mike for the link
It is indeed, in accordance with your comments a 533A. I believe the last time it was powered on it was working. This forum has proved to be extremely useful. Have a number of old valve sets and I'm clearing the decks so to speak! All the best, J |
Apart from a low hum it works well despite having all it's original components. I would not be surprised if your set does work, try it via a lamp limiter. A very nice set and built like a tank. :beer: Mark |
Thanks for all the responses on this item.
Much apprecaited. Would members be able to help on placing a value on this set? I believe it to be in full working order. Thanks for your consideration. Regards, J |
Re: Unknown Cossor Valve Radio. Identified as a Cossor 533A.
Hi Folks,
I'm looking for a back panel for this set. Is it possible any forum members have this as a spare? Please PM if so. Thanks for your consideration. Regards |
This is a rare set so although possible its unlikely.
Cossor's of this period used a thin plywood back with a small brass plate. When I'm next in Poole I should be able to send a picture from either the same or a contemporary model. Cheers Mike T |
