Ferguson 306T
Hi Guys
I am looking for a service sheet for my Ferguson 306T. I have looked on the internet but nothing comes up for this model. Anyone know where I could find one or another model similar The set I have got the crt is great and produces a really clear picture. I just have a sound fault. Amplifier is working fine but no signal coming through on the sound channel. Many thanks John |
Re: Ferguson 306T
1 Attachment(s)
John,
Please find attached the relevant Trader Sheet. I hope this is allowed. Jac |
Re: Ferguson 306T
1 Attachment(s)
One of the best and most popular Ferguson receivers ever. There are also HMV and Marconi versions but they bear no resemblance externally to the 306T. There is also a 21" version, the 308T.
If the audio amp is working there is not a lot to go wrong. I'm going to dive in the deep end and suggest it may be the detector diode that is hiding away in the final sound IF can W102. It's a bit of a fiddle to replace. The interference limiter diode load resistor maybe O/C [R159 1M ohm] but Ferguson employed excellent resistors and it is rare to find ones that have drifted. John. |
Re: Ferguson 306T
Thank you so much Guys
Will post some pics once sorted :) |
Re: Ferguson 306T
Hi Guys
What replacement Diode could I use for the detector diode above? Many Thanks John |
Re: Ferguson 306T
Virtually any germanium diode such as the OA90/91 etc will work fine. Check it's forward and reverse resistance. It's a pure guess but it might be O/C. Rocking the sound IF amp EF80 in it's socket should produce a few crackles. Complete lack of response suggests it's likely failure. Good luck! John.
Re: Ferguson 306T
Silly really since it was probably no bigger than a 26" CRT from a G8 and I used to change those at Philips with no problem..... |
Re: Ferguson 306T
A long time ago in 1964 when I was 16 [working from home] I had to replace the massive 70 degree MW53-20 21" tube in a Ferguson 308T. At that time I rode a Velocette Venom 500cc motorbike.
I removed the tube in the customers house and having no other form of transport sat it on the pillion with bungee straps around either side of the neck, clipped onto the underneath of the seat. It was quite secure as I rode the bike along Kingston Road back to Central Tubes at Merton from Derby Road Wimbledon. John the owner of central Tubes was horrified at the sight and insisted that he took the replacement tube, following me back to the customers house in his Austin 15cwt van. When you are young, nothing seems impossible. Why should it? It's only when you look back on your exploits decades later [with experience] that you realize how unwise it was to carry out these dodgy expeditions. Hope this did not divert from the 306T too much but I thought you might like to cringe at the story. Happy days! John. |
Re: Ferguson 306T
Excellent! I always love reading tales from people that were there, in the trade in times past.
Maybe you should start a thread about 'tales from the trade'? I'm sure it would yield some great stories... Strangely enough, last night I watched 'Ferguson- Men of Vision' on the 2009 BVWS DVD. It's a great film detailing the new automated production line & PCB fabrication process at Enfield. The sets they were making looked very similar, cabinet wise, to the 306T picture. I guess they were a bit later as they used mainly two PCB's. I could see a Fireball tuner, but my knowledge of Ferguson chassis' is woeful, so couldn't identify it. They were whirling tubes about like they were toys- always carrying & lifting them by the neck! 8-o There really is a treasure trove of material on those DVD's. All the best Nick |
