Old 19th Jul 2013, 5:51 pm   #1
ronbryan
Default Akai VT-110 reel-to-reel monochrome VTR
Does anyone have any dismantling instructions for this early (1970s) reel-to-reel Akai VTR?
The internal lead-acid batteries are useless, but it powers up with an external 12V supply applied and a motor can be heard to run all the time, but the symptom when play is pressed is that the take-up spool doesn't rotate and tape spill occurs.
In addition, neither fast forward nor reverse wind operate. The capstan motor runs, so I want to check to see if any belts that drive the other functions are perished.
Taking out all of the five obvious screws in the top plate, plus removing the pinch roller is not enough to release the plate. I'm reluctant to dive in too deeply without the help of a service manual in case some critical adjustment is disturbed. Is anyone familiar with this machine please?
Ron
ronbryan is offline
Old 19th Jul 2013, 7:04 pm   #2
radiotechnician
Default Re: Akai VT-110 reel-to-reel monochrome VTR
I do have the service manual here for the VTS 110. Section II ,
Case Removal has 9 photos showing how to remove the mechanism from the case.
Firstly, the great peril of these machines is breaking off the drum head pole pieces.
Until the transport is repaired no attempt at tape loading should be tried.
I did work on these machine in the 70's with the Akai Service Engineer
who was assigned to our shops because replacing and aligning head poles
had to be done with an optical fixture. (we had t wait until no buses were
on the street as they shook the building making task impossible)
Steps :
1 remove battery
2 remove 6 screws on bottom
3 front escutcheon remove 4 screws (where batt jack is)
4 (where monitor jack is) remove 2 screws
5 (where camera jack is) remove 1 screws
6 remove head cover, remove waeel cover (their spelling) short cover
adjacent head cover remove pinch roller screw and wheel
7 remove tape guide roller, remove sub pinch waeel
8 mechanical panel remove 4 screws
9 the chassis is free from case
The images in the manual are overlaid with red writing that needs a
magnifying glass to read.
Of all the tape machines, in all the world, good luck in messing with
this one
5
Steve Dow
VE7ASO
radiotechnician is offline
Old 19th Jul 2013, 7:45 pm   #3
ronbryan
Thanks Steve for your helpful detailed reply. I'll see how far I get with the dismantling without the photos.
If anyone in the UK has a manual, perhaps I could borrow it.
Ron
ronbryan is offline
Old 19th Jul 2013, 8:20 pm   #4
radiotechnician
If you want a scan of the two pages with the instructions, drop me an email.
I'll end them in full resolution where the red does show up.
Because the post originates from my ham station, I must have a name and a postal
address in the request, or a valid Amateur Radio Call sign.
S.
Steve Dow
VE7ASO
Old 23rd Jul 2013, 5:48 pm   #5
ronbryan
I've followed Steve's instructions (thanks Steve) and removed the deck from the case. In the unlikely case of anyone else doing this, please note that there is also a need to remove the tracking knob screw and knob (step 8a) before the deck will finally come from the case.
I've had a look at the deck and have found that the square section belt driving the take-up reel is broken and an idler tyre (possibly only used for ff and re-winding the tape) has turned to black gunge. Other belts and idlers appear ok as they have not yet turned to gunge or broken.
Does anyone know whether generic idler tyres to fit an estimated 19mm diameter wheel are still available?
I also need a square section belt with a 2mm side and 150mm circumference.
Ron
ID:	82219   Click image for larger version
ID:	82220   Click image for larger version
ronbryan is offline
Old 23rd Jul 2013, 6:55 pm   #6
Michael Maurice
Michael Maurice's Avatar
cricklewood electronics can supply you with a belt and terrys rubber rollers will rebuild your roller for you.
Michael
Forum Moderator
www.michaelmauricerepairs.co.uk
Michael Maurice is offline
Old 24th Jul 2013, 9:30 am   #7
ronbryan
Michael
Thanks for posting the links for belts and idler repair. I'm now trying to work out how to remove the idlers from the mechanism, so I can clean up the mess.
Ron
ronbryan is offline
Old 24th Jul 2013, 8:03 pm   #8
radiotechnician
This is the deck mechani layout.
Name:	Akai mechani 1.jpg
Steve Dow
VE7ASO
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
Copyright ©2002 - 2017, Paul Stenning.
