6th May 2012, 10:28 pm | #1 |
Beogram 1200 with bent silencer switch
Thanks, in advance, for reading this post. I have a Beogram 1200 which I'm trying to get working again. While examining the innards, I noticed that the switch which silences the pickup signal seems to have been bent out of shape. Please see the image below.
It's all curved, whereas in the service manual it all seems to be straight lines and 90-degree bends. Here is a close up of my switch. Does anyone know what this switch should look like in real life? |
12th Sep 2012, 11:04 am | #2 |
Re: Beogram 1200 with bent silencer switch
As a new forum member and not familiar enough with English technical vocabulary, I will do my best to enter this forum.
My first try is to ask you if you got adequate response? I had also a problem with this switch and was able to fix it: I have pictures to show how it should look like, but do not know yet how to display. E-mail? |
12th Sep 2012, 2:22 pm | #3 |
This must be some kind of record, a first timer being sorted out by another!
12th Sep 2012, 3:29 pm | #4 |
If all else fails you could bypass this switch. The fewer breaks in the singal path, the better.
Regards, Ben. |
12th Sep 2012, 4:36 pm | #5 |
I wouldn't worry about the supposed shape
It will have been "adjusted" so that it works (mutes the signal) |
12th Sep 2012, 6:31 pm | #6 |
Quit a common problem with the 1200. There are more pictures and discusion at "Beoworld" Search for Bent Switch.
John. Last edited by 60 oldjohn; 12th Sep 2012 at 6:38 pm. Reason: added search for... |
12th Sep 2012, 7:56 pm | #7 |
Thanks guys, I did bypass the switch in the end. Job done
