Old 9th Aug 2011, 10:22 am   #1
reddish75
Default Sugden A48
I'm just about to embark on the restoration of this Sugden A48 amplifier and have a few questions, firstly does anyone know what wattage the resistors are? Also are there any worth while mods out there?
Thanks
chris
reddish75 is offline
Old 9th Aug 2011, 1:05 pm   #2
D_S_J_R
D_S_J_R's Avatar
Default Re: Sugden A48
Seriously, it might be worth contacting Sugden for info, as they're still around.
Best wishes,
Dave
D_S_J_R is offline
Old 10th Aug 2011, 11:31 am   #3
BassoonBloke
BassoonBloke's Avatar
Smile Re: Sugden A48
Hi Chris,
There seem to be a few different versions of this amp. I seem to have a MK1 without the cutout relay. Finding the correct circuit diagram seems quite tricky (i've yet to find the correct one for my amp ).
If i were you i would replace the main power supply smoothers and output caps as they are getting on a bit now (and are probably drying up and losing capacity).
Other than cleaning dirty switches and generally checking for frying resistors, leave it as is and see how it performs.
This amp has been reported as running in Class A, this is not the case and infact it runs Class B and quite cool (the Drivers run in Class A).
Good Luck.
Cheers,
Alan.
BassoonBloke is offline
Old 10th Aug 2011, 2:44 pm   #4
reddish75
No relay in mine, the version i have has just j.e sugden on the front in a wooden sleeve.
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
Copyright ©2002 - 2017, Paul Stenning.
