Old 12th Jun 2011, 2:50 pm   #1
super_7b
Default Farnell L30 PSU
I have one of these PSUs and it isn't performing quite right. Having had a look inside, I'm not surprised, as the caps and resistors look original and it appears to be late 1960's or very early 1970's (all the transistors are OCxx series).
I am going to replace the electrolytics and any off-value resistors, but I would like to know how to set it up properly. Has anybody got a circuit diagram, or better yet, a full manual for one of these? The one I found on this site relates to a "newer" (relatively) model with 2N transistors.
BR
Mick
super_7b is offline
Old 12th Jun 2011, 8:00 pm   #2
Stockden
Default Re: Farnell L30 PSU
Hello Mick,
This manual shows OC type transistors in the circuit. With luck it's the one you need.
Hugh
Stockden is offline
Old 13th Jun 2011, 6:20 pm   #3
super_7b
Thanks a load Hugh,
What a star! Exactly the model I have, an L30.
Having opened it up for a fuller inspection, it has been "repaired" by someone with what looks a hot poker at some time and a transistor had been replaced. In doing so, a couple of mounting lands have lifted and one had parted company with the track on the board. I think this is why it wasn't working correctly.
I will replace all the electrolytics while it is apart as they are dated Nov 1963 to Mar 1964. I am impressed they have held up for so long.
BR
Mick
super_7b is offline
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
Copyright ©2002 - 2017, Paul Stenning.
