Old 29th Mar 2011, 8:10 am   #1
Trevor
Default Sinclair Z12
I am sure most of us can remember the brave new world as promised to us by Sir Clive!
One of his offerings was the Z12 I can remember saving my paper round money and purchasing one of these
Do any of you have any stories relating to this module?
I have obtained a few of these and will shortly post my intepretation of the circuit, it's a liitle minamilist re stability etc!
regards For now Trev
Trevor is offline
Old 29th Mar 2011, 10:46 am   #2
dave walsh
Default Re: Sinclair Z12
Hi Trevor. I happen to have some paperwork on this including a set of Super IC-12 Temporary instructions with circuit and wiring diagrams. I had to return my unit three times over the period Oct to Nov 1971 accompanied by increasingly bitter correspondence but to be fair, I did get a lot of feed back from the Company [as well as the IC ] which more or less settled down in the end, after some caps had been replaced or rewired. On 1/12/71 my job No is 23579 but I don't know if that reflects sales? I'm complaining at this point that I've spent 7 overall. Despite the difficulty experienced, I recall that I wanted it to work, not get a refund. It's hard to explain in today's world how attractive the prospect of an amp in one IC seemed [now the novelty is in a valve amp]. As I recall, I did run it for some time as one channel in an early stereo setup ie SP25 deck/ceramic cartridge/cabinets home made and speakers salvaged from a scrap PA system. The other channel? Via my tape recorder in amp mode! I would think that Mr Tedechi, the Sinclair, expert over in Brighton, should be a good source of info. Hope this helps you.
Dave W
dave walsh is offline
Old 29th Mar 2011, 11:30 am   #3
Herald1360
Herald1360's Avatar
Location: Near Witney, Oxfordshire, or Leominster, Herefordshire.
Some confusion here I think..... the Z12 was a discrete amp module with a couple of TO3s as output, the IC12 was ISTR a rebadged Texas audio IC.
.........._______
.....___/|__|__|\____
.=.( _---\__|___|_---_)
.........O...Chris....O
Herald1360 is offline
Old 29th Mar 2011, 12:27 pm   #4
dave walsh
Yes you're right Herald. Sorry about that Trev.
I never saw the Z12 but no doubt there's plenty to be said about both products.
Dave W
Old 29th Mar 2011, 12:34 pm   #5
radiotircoed
radiotircoed's Avatar
You're correct Herald. The IC12 was a Texas reject re badged as the Sinclair IC12.
I was a schoolboy at the time and saveD up for a pair of these. One spontaneously combusted due to internal oscillations... And yes I did fit substantial heat sinks!
Bob W
Radio Tircoed - Working for the Community
radiotircoed is offline
Old 29th Mar 2011, 3:04 pm   #6
roffe
I have a Antex leaflet with schematics and instructions for the Z12.
roffe is offline
Old 29th Mar 2011, 3:25 pm   #7
gingpeakin
I had one of these. It was the most powerful amp I'd ever had - I was 10 at the time I think. I used it with the great big speaker that I'd pulled from an old floorstanding TV. It was a Pye something and I put the whole lot in the cardboard box from a 'continental quilt'. Duvets were a later name. It blew up in the end of course like most other Sinclair stuff. I still have a Project 60 set with tuner and active fiilter which worked last time I tried it. Did have a pair of Q16s but they blew up as well.
Ging
gingpeakin is offline
Old 29th Mar 2011, 5:24 pm   #8
P.Pilcher
Not being a fan of Sir Clive's circuits I satisfied myself with a pair of Dinsdale designed 10 watt amplifiers using OC28's in those days. However one of my fellow electronics university students was facinated with the switching circuitry used in these Sinclair amps and acquired a pair. He managed to get them to work and a few days later was talking to a neighbour to the digs where he lodged. She complained that her radio wasn't working well and asked if he could have a look at it. He found nothing wrong, but learned that the problem was intermittent severe interference. Further enquiry revealed that the periods of this interference coincided precisely with the times he used his Sinclair amps! Needless to say, said amps were rapidly withdrawn from service!
P.P.
"Ohm's law rules here" - Oxygen free speaker cable not required! (Quote: Quad Service lab)
P.Pilcher is offline
Old 29th Mar 2011, 6:26 pm   #9
spontaflex
From memory I think it was the X10 that was a PWM switching amp not the Z12.
Geoff
spontaflex is offline
Old 29th Mar 2011, 6:50 pm   #10
ParcGwyn
ParcGwyn's Avatar
My father bought a Sinclair Z12 and was going to clone it and make a stereo amplifier, but in the end he used a Mullard 10W design with OC28s as output transistors and I think OC16s as drivers. He still has the Z12 unused and I copied the circuit diagram down a few months ago with the intention of building a pair when I have time.
Dave
GW7ONS
www.parcgwyn.talktalk.net
ParcGwyn is offline
Old 29th Mar 2011, 6:54 pm   #11
Trevor
I have made my own diagram but I find points a bit wierd and would be gratefull if any one could post the circuit!
I also remember playing with my first Z12 but can not remembr what happened to it
regards trev
Trevor is offline
Old 29th Mar 2011, 7:16 pm   #12
Trevor
Please find attached a crude sketch of the circuit to the Z12
I am not to sure I have got it correctly so would like a comparison schematic
it is a really crude affair re no emitter resistors on the output devices
Under biased on the output devices
No bootstrap on the main voltage amplifier
the heat-sinking also leaves a lot to be desired all in all a shocker
however i remember it sounding not to bad
all comments welcome
regards trev
Trevor is offline
Old 29th Mar 2011, 7:36 pm   #13
roffe
Here's the schematic.The component values for the amplifier are not given in the leaflet(!),only for the tone controls and the preamp.....
The values are my own,noted a long time ago when I had a Z12.
C5 is 1000uF.
More tomorrow.
Name:	Sinclair Z12 amp schem.jpg
roffe is offline
Old 29th Mar 2011, 7:41 pm   #14
Trevor
Roff
Thank you very much I can see my circuit is the same once again you have provided a good comparison !Do you have any memories of using your Z12? Please advise as I am interested in the social history as well as the technical
The only reason I do this is so that the information will get onto the internet and these things do not get forgotten
best regards Trevor
Trevor is offline
Old 30th Mar 2011, 3:13 pm   #15
toshiba tony
toshiba tony's Avatar
as some of you pointed out, the z12?, not doubting anyone but i dont remember it, ic12 yes, memory usually ok, i think the ic12 used an s776013nd, and thats without research, prob wrong though, anyone?
toshiba tony is offline
Old 30th Mar 2011, 4:17 pm   #16
Herald1360
Herald1360's Avatar
ISTR SN76013, this looks familiar:
http://www.cricklewoodelectronics.co...2&cat=0&page=1
.........._______
Old 30th Mar 2011, 7:50 pm   #17
tonyharker
If anyone is interested Ive got a scan of the original manual (without values) for the Z12.
tonyharker is offline
Old 30th Mar 2011, 8:34 pm   #18
roffe
Trevor,I'm sorry but I have no special memories of the Z12,other than that I got sound out of it.I only had one single amp,so no stereo.I still should have it somewhere,but you know how it is...
To me these old,simple amplifiers are much more interesting than any japanese monster from the 70's!
Name:	Sinclair Z12 feedback.JPG
ID:	48867   Click image for larger version
Name:	Sinclair Z12 inputs.jpg
ID:	48868   Click image for larger version
Name:	Sinclair Z12 stereo.jpg
ID:	48870   Click image for larger version
Name:	Sinclair Z12 tone controls.jpg
ID:	48871   Click image for larger version
Name:	Sinclair Z12 volume.jpg
roffe is offline
Old 30th Mar 2011, 9:50 pm   #19
Lucien Nunes
Lucien Nunes's Avatar
I have a pair of Z12s that I got second hand with a Stereo 25 preamp. They're not quite identical, one had Lemco electrolytics and the other unbranded, one PCB brown and one black, the transistors were slightly different too. My first challenge was to make them work, which involved changing a few bits; unfortunately this resulted in a couple of tracks peeling off the PCB. Attempts to reinforce suspect sections caused the PCB to curl up. Maybe the board material was substandard too.
Once they were 'working', I decided to assemble them with the preamp into a compact, Sinclair-sized box to use on the boat, because they would run directly from 13V DC. I modified a Japanese HiFi tuner to do likewise, and set about finding a suitable pair of speakers. The next time I powered the Z12s up, at least one transistor was bad...
At this point they were demoted to the status of curiosities rather than amplifiers and have remained as such, although I did eventually repair the faulty module and have powered them up not so long ago.
Z12 advantages: Size
Z12 disadvantages: Performance, Reliability
A feature-set shared by many other Sinclair products!
Yes I love Sinclair stuff, amplifiers that oscillate and computers that overheat, calculators that give wrong answers, it's all part of the fun.
Lucien
Three anodes good, six anodes better!
Lucien Nunes is offline
Old 30th Mar 2011, 10:10 pm   #20
Red to black
Red to black's Avatar
Hi, for all things Sinclair, including audio and calculators as well as the more well known home computers, see this website:
http://www.nvg.ntnu.no/sinclair/contents.htm
On this site you can find some of the original adverts for the Sinclair products, it seems Sir Clive 'slightly over exaggerated' the specs and performance figures for some of his products, allegedly.
I have posted this link before, elsewhere on the forum, but on an unrelated subject matter.
Cheers,
Baz
Red to black is offline
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
Copyright ©2002 - 2017, Paul Stenning.
