Old 25th Jan 2011, 10:36 pm   #1
Helfer66
New Member
Default BSR Tape deck
I Have a Reel to Reel tape recorder Made by BSR I am asking if any one knows what would be the best way to transfer quite a few tapes to a CD recording unit
It has positions marked on the rear panel marked Speaker, Radiograme, and Record. Can any one please advise me. thank you.
Helfer66 is offline
Old 26th Jan 2011, 9:24 am   #2
Paulus.d
Default Re: BSR Tape deck
My usual method is to connect the EXT.Speaker to the Line in of the Recording equipment, PC, Minidisk or whatever...
You have to be quite careful with the input volume level so not to overload the recorder, so start with it on minimum and turn up to find the best level.
Regards Paul
Paulus.d is offline
Old 26th Jan 2011, 10:00 am   #3
Andrew2
Helfer, it may be better to try the 'Radiogram' socket first. I'm not sure if it's an input or an output, but if it is an output the level may be more suitable than the LS out. There tends to be quite a lot of hum and noise on the LS out.
Andy G1HBE.
Andrew2 is offline
Old 26th Jan 2011, 10:13 am   #4
AndiiT
AndiiT's Avatar
Any chance of a picture of your recorder?, As has been mentioned before in these forums, a picture speaks a thousand words.
BSR were the makers/suppliers of the mechanisms for many different tape recorder manufacturers, that said I do have a BSR branded machine which is a Fidelity clone.
I would guess that the Radiogram socket is an input only route so the Loudspeaker socket may be your only option of an output suitable for feeding into the input of your CD recorder (or alternatively the audio line card of a PC)
If you are handy with a soldering iron and capable of dismantling your machine, a more suitable signal will be found across the outer two connections of the Volume/Recording level control.
If you do have to use the Speaker output it may be wise to attenuate the output using a resistor network similar to the one shown on this page before feeding the signal in to the CD recorder.
Regards
Andrew
AndiiT is offline
Old 23rd Jun 2012, 9:55 am   #5
allander
allander's Avatar
Post Re: BSR Tape deck
BSR TD10 Service Manual
Just a note for anyone seeking a copy of the 'service manual' of the TD10 3 speed BSR tape deck I have a copy which I've scanned to 9 .jpgs not having a clue about creating a .pdf copy - if anyone can convert it (or rather the .jpgs) to .pdf I can send the images to them and it might be useful for the group - one thing it doesn't seem to give info about is belt sizes and how to replace them (I think the sizes are 107mm X 2.4 round capstan and 90mm X 1 round counter). Regards Rog.
allander is offline
Old 23rd Jun 2012, 2:04 pm   #6
Refugee
Refugee's Avatar
Radio gram sounds to me like a connector that is linked to a Hi Fi unit for both record and play.
A cable will be required that can be purchased. Make sure it has the right connectors at the other end.
Refugee is offline
Old 23rd Jun 2012, 9:52 pm   #7
david freeman
The radio/gram socket on most BSR deck recorders is an input socket. If your machine has a socket marked 'mon' or monitor, then this can be used as a line output to feed a line input on recording equipment or PC. This should give better results than using the Ext LS socket.
As an example, I have connected a Fidelity Playmaster this way to a hifi amp and speakers with surprisingly good results.
david freeman is offline
Old 23rd Jun 2012, 10:02 pm   #8
AndiiT
AndiiT's Avatar
If the BSR is a Model 222 or 224 this is basically a clone of the Fidelity Argyll minor series of recorders and will not have the monitor output socket fitted that the Playmaster has, just Mic input, Radio/Gram input and Ext L/S output sockets.
Andrew
AndiiT is offline
All information and advice on this forum is subject to the WARNING AND DISCLAIMER located at http://www.vintage-radio.net.
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
Copyright ©2002 - 2017, Paul Stenning.
