24th Jan 2011, 10:29 am | #1 |
Quad 44 Control Unit
This Quad 44 control unit suffers from a low level rustle, like some sort of electrolytic problem but it may be the volume control track. I cannot seem to nail it down, and it does seem to be worse after power on, tying in with the capacitor theory.
Although I have circuits in the user manual and have found a service manual, these both show the circuits for the earlier versions. Mine is s/no 24221, a very late one, and the tone control board where I suspect the problem lies is type 12784-1, rather than the earlier 12512-9, and it is very different. The volume control is a custom unit in rectangular black case which solders directly to the tone control board rather than flying leads on the earlier ones - if it is the volume control I cannot see it being available. Does anybody by chance have the circuit of this later 12784-1 pcb, or any suggestions as to what is causing the problem. Thanks Dave |
24th Jan 2011, 11:43 am | #2 |
Re: Quad 44 Control Unit
I know nothing about Quad - are there any op-amps in the 44?
The reason I ask - I had similar problems in one channel of an old Teac mixer - sounded like DC on the fader, but I couldn't measure any on there. Recapping didn't fix it, and changing the fader didn't fix it, but eventually I decided to change one of the dual op-amps and the problem just disappeared. |
24th Jan 2011, 7:08 pm | #3 |
The board in question has four TL072 op-amps on it. It is possible that one of them is duff so I might try to see the noise on my scope. It would be a lot easier of course if I had the right circuit.... Thanks for the suggestion.
Dave |
24th Jan 2011, 7:25 pm | #4 |
This should cover your 44.
I've had 2 problems with mine, one was dry joints on the through board connections on the motherboard and the other was with a poor connection on the cable connecting the motherboard to the tone control board. Keith |
24th Jan 2011, 7:34 pm | #5 |
Is the 44 similar to the 34?
If so, this thread may help. https://www.vintage-radio.net/forum/...ad.php?t=46783 James. |
25th Jan 2011, 9:56 am | #6 |
Dada Electronics can be trusted for decent advice, spares and tweaks, although the later 44 was better than the earlier one. They also have a "Revision Blogspot" which may be of help in service and troubleshooting.
At least Quad still have a service department in Huntingdon, although their repairs tend to be of the get-you-going type, rather than full refurbishments. |
25th Jan 2011, 7:31 pm | #7 |
Many thanks KeithsTV for the circuits, they are indeed the correct ones. I did have one leaking electrolytic which had corroded the board, replaced that and cleaned it up. I suspect one of the other 100uF caps is the cause of the problems so will change the lot, hopefully tomorrow.
Dave |
27th Jan 2011, 9:53 am | #8 |
Leaky caps affect the Quad 34 too...
31st Jan 2011, 5:07 pm | #9 |
I have finally managed to sort out this Quad 44. I had originally cleaned up the mess from the leaking caps, but obviously not enough. It took a bit of detective work, with the help of the Keith's circuits and isolating stages one by one to show that it came from the middle TL072 - IC702 on his circuits. When I removed that I found there was a small amount of gunge on its pins. A thorough clean of the chip and the pcb under it sorted out the problem. No crackles or the like, good nice audio.
Thanks for the help. I am sure the owner will be pleased. Dave |
31st Jan 2011, 8:48 pm | #10 |
I went off quad with the 44 control unit ! They were expensive and when you consider all you are listening to is a TL072 op amp at about £1 I rather got diselusioned with them
regards Trev |
