Old 12th Dec 2010, 4:19 pm   #1
davegsm82
davegsm82's Avatar
Default British National Radio School - DIY Oscilloscope
As per my other thread here ----> https://www.vintage-radio.net/forum/...ad.php?t=62750
I'm looking for information about a self-build oscilloscope I bought many years ago but never got built.
The pictures can be seen in the other thread, I'm after the build instructions or circuit diagrams if anyone still has then kicking about the place.
Any help with this is greatly appreciated.
Thanks, Dave.
davegsm82 is offline
Old 12th Dec 2010, 9:48 pm   #2
Ed_Dinning
Default Re: British National Radio School - DIY Oscilloscope
Hi Dave, I have the details of various Philips design students scopes that use similar valves. If you are over near the Metro centre you can give me a call and look at them.
It may be possible they are the same, or you may be able to build something similar.
Do you have a parts list?
Ed
Ed_Dinning is offline
Old 12th Dec 2010, 10:22 pm   #3
davegsm82
davegsm82's Avatar
Hi Ed,
I believe I've actually visited you on a previous occasion, you donated some valve bases to me for an amplifier I was planning on building (was based on KT88's in push pull) but that didn't get made in the end. I was the nutter that arrived on the motorbike.
Anyway, unfortunately I don't have any details about the 'scope other than the parts I have in the box. It was partially built when I received it, but with no instructions and pieces hanging off I decided to strip it down completely so I could start fresh.
I have just remembered that I think the senders name is still on the box, I wonder if he's someone on the forum?
Dave.
Old 11th Jan 2011, 11:17 am   #4
davegsm82
davegsm82's Avatar
Just a little bump in case anyone hasn't seen my request.
Dave.
Old 11th Jan 2011, 4:27 pm   #5
Bumblebee
Bumblebee's Avatar
Location: Wolverley, Kidderminster, Worcestershire, UK.
Hi Dave, Just read your post. I have one of these. Still work's as far as I know. First thing I ever built back in 1978, and an expensive course. I think I still have a circuit diagram for it, and the all the buff some where. I will have a look tomorrow.
All the best.
Mark
(Bumblebee)
Bumblebee is offline
Old 11th Jan 2011, 9:20 pm   #6
davegsm82
davegsm82's Avatar
Hi Mark,
I'd be extremely grateful if you could locate this information, I hate having it laying about unbuilt with all the parts there!
I look forward to hearing from you.
Thanks, Dave.
Old 11th Jan 2011, 9:22 pm   #7
Ed_Dinning
Hi Dave, call me if you get stuck or need assistance.
Ed
Old 12th Jan 2011, 11:12 am   #8
Bumblebee
Bumblebee's Avatar
Hi Dave, found circuit diagram. I've have taken some photo's. If you send me a PM with your email I will send you the diagram.
The CRT number is DG7 - 131. Not sure tho what make it is.
All the best.
Mark.
ID:	45037   Click image for larger version
ID:	45038   Click image for larger version
ID:	45039   Click image for larger version
Old 12th Jan 2011, 8:12 pm   #9
ParcGwyn
ParcGwyn's Avatar
Hi Mark,
I would like to see a copy of the circuit diagram if possible.
Regards
Dave
(GW7ONS)
http://www.parcgwyn.talktalk.net
ParcGwyn is offline
Old 12th Jan 2011, 8:18 pm   #10
Bumblebee
Bumblebee's Avatar
Hi Dave, Please send me an PM with your email address, I will glady send it to you. I also forgot to add in my last 2 reply post I also so have the insurction manual. I can scan it I think all pages are there, but it will take a few hours to do.
All the best
Mark.
Old 18th Jan 2011, 10:14 am   #11
Bumblebee
Bumblebee's Avatar
Unfortunatly I can't scan the manual as it is bigger then A4. The Scope is called ''Lernakit''
Mark.
Old 19th Jan 2011, 3:50 pm   #12
davegsm82
davegsm82's Avatar
Hi Mark, got your email. Its ok about not being able to scan it, I dont mind as I have the main bit I was after which is the circuit diagram.
I believe I can pretty much work it all out from there if need be. Does the manual have the tagstrip diagrams showing part placement?
Thanks, Dave.
Old 19th Jan 2011, 4:47 pm   #13
Bumblebee
Bumblebee's Avatar
Hi Dave, yes it does I will email you later.
All the best.
Mark.
Old 14th Jan 2012, 1:06 pm   #14
phill1029
Hi Bumblebee,
Reading an old thread, I notice you had a manual for the valve Learnakit scope. Have you still got this,and if so,would you be prepared to sell it or a copy of it?
Thanks.
phill1029 is offline
Old 20th Jan 2012, 7:57 pm   #15
phill1029
Hi Bumblebee,
I have just received the disc and looked at the manual. It has brought back many memories.
As I read through the manual, I remembered various stages of the building of the two valve oscilloscope. I remember sitting a the table with bits of partly built scope and wondering what it was all about! I cannot remember how much it cost for the course, only that I paid about 50p a week for the course. Getting a stage at a time to build and then go over some course work. When I finished building the oscilloscope, it would not work. The mains transformer had a shorted turn and had to be replaced. Once replaced, the scope worked just fine and I had to then use it for a number of experiments into electronics. I am not sure how many experiments, I think it may have been up to 40. I was this manual, a construction document and another document outlining all the experiments – I think?
Anyway, it was money well spent! There must have been thousands of these courses sold over the years. I am surprised that information on them is so hard to find. Maybe someone should start a web site on the subject!
Haven’t switched the oscilloscope on for many years so I expect the capacitors have dried out, so I would need to replace all of them. Having said that, there were not that many components altogether. It just seemed that way all those years ago! What I would like to do with the manual is to write it out using a suitable font like courier and use the original diagrams. Then have a single PDF file. That is something for later. Thanks for the tremendous amount of work you have put into getting this manual into PDF files. Must have taken quite a while?
Thanks,
Phill1029
Old 11th Jul 2013, 2:10 pm   #16
AnthonyC
Hi All
I came acoss this forum after searching for information on the LearnaKit scope. I have just bought a Hameg HM203-4 scope off Gumtree for 13 pounds and the chap kindly gave me an old LearnaKit scope and some course notes. The scope seems to be in Ok condition though I sure some bits will need replacing. I would love to get this scope going again and wonderef if anyone might have any construction notes for this.
Regards
Anthony
AnthonyC is offline
Old 2nd Oct 2013, 9:16 pm   #17
shufy62
Hi Antony
I have just seen your request for notes on the "Lernakit" Oscilloscope.
My father who passed away some years ago had an oscilloscope which he probably built, I also have the notes on it as well, if any of this is any use to you I would like to hear from you, as my mother passed away this year so I have been clearing out her loft and found the oscilloscope, which she had kept.
Kind Regards
Lynne
shufy62 is offline
Old 7th Oct 2013, 6:32 pm   #18
phill1029
Hi shufy62,
I would be interested in any info on the learnakit Oscilloscope.
Can you help please?
Thanks
phill1029
Old 8th May 2014, 4:11 pm   #19
middlefour
Hi all, just stumbled across this forum. With a house move coming up I came across my old Lernakit Oscilloscope, to my amazement it still worked!! I have all the documentation for it if any one would like copies. I see a previous post was asking about the make of the CRT, it was a Mullard. I still have the guarantee for mine, probably run out now as it was some 41 years ago that I built it. When I get time, after the move, I might have a play with it and see what use I can put it to.
Steve
middlefour is offline
Old 25th Aug 2014, 2:16 pm   #20
Trevor
I have also dug out my learnascope can you send me any information that you have
Trev
Trevor is offline
