9th Dec 2010, 6:26 pm | #1 |
Anyone Recognise this scope?
A long time ago, I bought this DIY scope from someone, I cant even remember how I came to buy it but I did.
I beleive its a 'Heathkit', possibly, something to do with a self-teach course I've seen in old Practical wireless or Practical Electronics mags. It consists (electrically) of a Mullard D7-5 or D7-31 tube (cant remember which, I have both) and there are only 2 valves used as well as a silicon bridge rectifier. I beleive the valves are possibly EF80's or ECF80's, I have a box with 2 of each with the scope. I'd like to find the original schematics or build instructions, then possibly I will re-build it to this spec or find another more accomodating design, ultimately with more valves and features. Here are the pictures anyway... |
9th Dec 2010, 7:06 pm | #2 |
Re: Anyone Recognise this scope?
Not Heathkit (at least not in the sense of being produced by Heath/Daystrom) but certainly looking like one that appeared in ads for one of the postal radio/electronics courses in the 60's & 70's. Unfortunately I don't have any information on it.
Hugh Last edited by Stockden; 9th Dec 2010 at 7:06 pm. Reason: clarification |
9th Dec 2010, 8:12 pm | #3 |
It certainly looks like the one in the attached advertisment. If anyone has a copy of the circuit diagram they can post I would like to see it.
If you are interested in just building a simple scope see my website below. Dave GW7ONS http://www.parcgwyn.talktalk.net Last edited by ParcGwyn; 9th Dec 2010 at 8:36 pm. Reason: adding more info |
10th Dec 2010, 12:35 am | #4 |
Hi Dave.
Thats the Very advert I was thinking about! It does look a lot like that one if not identical. I think I searched a long time ago for the 'school' at the bottom of the advert, to no avail. I'd love it if someone actually has the schematic for it, I hate it sitting there just being a box of bits. Its not that I need a scope either, I have a couple of Tectronix TDS range LCD scopes, but I just love the glow of my analogue valve ones as much. Thanks, Dave. |
10th Dec 2010, 4:01 am | #5 |
I can confirm that the scope is exactly that shown in the advert. I actually purchased that course and built the scope in 1969 when I was a wee lad.
It was not cheap and I must say not a very useful scope , good enough as a monitor , I think it only had a bandwidth of about 1 MHZ ( could be wrong ). However you have got to remember that in those days scopes were very expensive and very few amateurs had acess to them privately. Regards Mike |
11th Dec 2010, 1:07 am | #6 |
Hi Mike,
Its a longshot, but you don't still have the documentation for it do you? Thanks, Dave. |
11th Dec 2010, 1:13 am | #7 |
Hi Dave,
I am afraid I do not , I remember it was published by the British National Radio School, I would post a request for it because I bet somebody has got it. Mike |
16th Jan 2011, 3:13 pm | #8 |
Hi Dave,
I found this out on the internet some while ago, i am sure it is the right schematic. //Staigen |
16th Jan 2011, 4:54 pm | #9 |
Well done, that is definitely the scope I built. Be careful with the Y plates It is easy to get a shock off those sockets.
Mike |
16th Jan 2011, 6:25 pm | #10 |
What are the Y outputs for? And wich tubes are used(I mean the pentodes)? Let me guess, its EF80:s or EF184:s. Also, can anyone explain to me how the T/B oscillator works? I have seen this type of osillator in many DIY scopes!
//Staigen |
17th Jan 2011, 10:28 pm | #11 |
Wasn't there a company called "Philip Harris" that sold 'scope kits? I may have had one before we moved here. No idea what became of it. Cheers, Pete
17th Jan 2011, 11:10 pm | #12 |
It sees to be a circuit called either a Miller Transitron, or Phantastron. These are a crafty bit of circuitry and were very widely used in WWII radar gear. A Google on either of the above names should tell you all you want to know.
18th Jan 2011, 12:59 am | #13 |
Location: Wolverley, Kidderminster, Worcestershire, UK.
18th Jan 2011, 8:36 am | #14 |
Ok, I belive it was right here I found it then.
I would also like to build this scope, but I dont have a DG7-31 CRT, only a DG7-32. Someone that have one for sale? //Staigen Last edited by Brian R Pateman; 18th Jan 2011 at 1:32 pm. Reason: Quote fixed. |
18th Jan 2011, 8:50 pm | #15 |
Hi Staigen, see if you can find the datasheet for the tubes and you may find they are interchangeable, or only require a minor mod the the voltage chain across the tube.
Happy building, Ed |
18th Jan 2011, 11:53 pm | #16 |
19th Jan 2011, 7:31 pm | #17 |
The DG7-31 was designed for the x-plates to be driven asymmetrically whilst the DG7-32 was designed for symmetric operation. An alternative to the DG7-31 is a DG7-6 although you may have to adjust a few voltages.
Regards Dave GW7ONS www.parcgwyn.talktalk.net |
21st Jan 2011, 10:37 pm | #18 | |||
Hi, sorry I havent replied earlier.
Frank's tube datasheets I have known for several years, too. I belive I can build it with the DG7-32/01 that I already have, and will start a new thread when i do, with pictures and all, that is going to be fun. Quote:
//Staigen |
14th Jan 2012, 2:14 pm | #19 |
Do you still need a crt?
Rob.
We have done so much, for so long, with so little, we are now qualified to do anything with nothing. |
