10th Oct 2010, 4:48 pm | #1 |
Product detector circuit
I have been an avid SW listener for years , and would like to hear from people who have built a successful product detector .
I am using a Eddistone 640 , and a GEC BRT400 receiver. |
10th Oct 2010, 5:37 pm | #2 |
Re: Product detector circuit
Valve or transistor? There are some designs on the Web which look as if they can be built in to existing receivers. I once built a 12 transistor shortwave superhet with a product detector and it worked extremely well. That was nothing more than a simple two transistor circuit (using OC45's I think) so that gives some idea of how long ago it was....!
The only valve circuit I can recall now is in the RSGB handbook that uses an ECC82. I reckon you could build that into the Eddystone without too much trouble and according to the text, can also be used as an 'outboard' item. There are no special parts required and most of the parts should be found in the average scrapbox. Not sure about reproducing the circuit here because of copyright issues. Remember you'll still need to retain the normal AM demodulator because the product detector will not demodulate AM so some switching will be necessary. SB
10th Oct 2010, 5:42 pm | #3 |
I have heard of many detectors, but not this. Please could somebody tell me what a product detector is? I know that using the Base to Emitter junction on a transistor (I have used a OC45) gives an amplified signal at the collector.
10th Oct 2010, 5:56 pm | #4 |
Product detectors are mainly found in Communications receivers. They are particularly useful when listening to SSB transmissions. Very simply, they are a mixer type demodulator where one input is fed directly with the I.F signal and the second input from the BFO (or the carrier insertion oscillator). The valve (or transistor) then mixes the two inputs to provide an AF output. It won't reproduce AM because, as the name implies, it requires two inputs to provide the output. The circuit is quite simple and just requires a small amount of RF filtering on the output.
This is a very simplistic description and no doubt someone else can give a more detailed description if necessary. SB
10th Oct 2010, 6:23 pm | #5 |
hmm, if i am not all wrong that means about same effect as a slightly oscillating regenerative receiver. please tell me if i am wrong.
more or less a stable oscillation and then add in the modulation as a product or difference depending on what part of the signal is picked up with the LC circuitry. |
10th Oct 2010, 6:42 pm | #6 | |
http://en.wikipedia.org/wiki/Product_detector Alan |
10th Oct 2010, 8:09 pm | #7 |
It will do AM, but unless very stable local oscillators you'll easily get a hum to whistle. (the product of AM carrier and injected local osc). Note that a stable oscillator (BFO) doesn't solve it, you need the L.O. for the Superhet to be stable too. It will also do FM as well as SSB or Morse. The main original purpose of BFO was for Morse. To deliberately offset by about 800Hz from the carrier, not SSB.
10th Oct 2010, 10:50 pm | #8 | |
A few added points. The level of the BFO (Beat Frequency Oscillator) injection into a normal diode AM detector has to be high for this method to work. This upsets the operation of the sets AGC circuit. The AGC sees the BFO as a very strong signal and turns the sets gain down accordingly. This is why most sets of this type tell you turn the AGC off and use the RF gain control. A product detector, which is usually tapped off from the same place as the diode detector,does not cause this effect. A set fitted with a product detector is easier to use. There is usually a switch marked LSB(below 7 Mhz), USB(above 7Mhz) and AM. Select the correct one and use the main tuning until the signal is intelligible. A product detector is just a variation of the sets mixer circuit. Sorry if this is a bit wordy Al
I won't tell you how I discovered that. |
10th Oct 2010, 11:06 pm | #9 |
I'm currently toying with a product detector for an RA17L and would also be interested in any designs going (especially the coils). I was planning to use the BFO on-off switch to switch between ssb and am. As I understand the BFO control would operate at the same settings as before (ie +/- 1.5 - 2.0 KHz for LSB / USB depending on filter setting).
Rob.
We have done so much, for so long, with so little, we are now qualified to do anything with nothing. |
10th Oct 2010, 11:35 pm | #10 | |
I have the circuits from the copyright 1961 3rd edition and the copyright 1968 4th edition of the RSGB handbook in front of me. The circuits are basically the same standard circuit although component values change and an RFC turns into a resistor. Would we infringe copyright by sending the the cct and text to the OP? Al
11th Oct 2010, 12:02 am | #11 | |
If you do try it, Rob, please let me know how it works out. http://www.vmarsmanuals.co.uk/newsle...t_detector.pdf Al. / Skywave. |
11th Oct 2010, 12:09 am | #12 | |
On my Yaesu FRG 7000(also a Wadley Loop receiver) the AM, USB, LSB switch does 2 things. Between AM and USB/LSB it switches crystal filters from 8khz down to 2.2khz then the USB, LSB positions switch different crystals into the BFO. Al
11th Oct 2010, 7:56 am | #13 |
What's wrong with the existing if filtering?
At least adding a product detector would allow the s meter and agc to work properly. Rob. p.s. thanks for the link Al, I'd never thought of doing it that way.
11th Oct 2010, 8:07 am | #14 | |
Please don't turn this thread into a discussion about copyright.
11th Oct 2010, 11:03 am | #15 | |
There used to be a kit sold in the states for the collins R390A which was quite succesful , this was based on modern components and had good reviews. Mike |
11th Oct 2010, 2:36 pm | #16 |
A product detector is a mixer, therefore any mixer circuit can be modified to act as a product detector. You just have to change the output to handle audio instead of RF, and probably low-pass filter the remaining RF away. One thing to bear in mind is that a product detector is probably handling larger signals than a front-end mixer (except in a direct-conversion receiver) so signal handling is more important than noise.
If you are familiar with broadcast receivers, then one thing to try is an ECH81 product detector. Input from IFT, oscillator triode uses single-tuned IFT (or half an IFT), output is a resistor instead of an IFT. Unusually, this product detector can even have AGC too! |
11th Oct 2010, 2:43 pm | #17 |
As promised.
11th Oct 2010, 5:34 pm | #18 |
Those are the same circuits I have although my RSGB edition is slightly later dated June 1969. They give the value of the RF choke in the 12AU7 (ECC82) circuit as 1.5 to 2.5mH. Should be dead easy to build that into an exsiting receiver.
SB
11th Oct 2010, 7:03 pm | #19 |
Thanks for the circuits and comments i hope to be building them to see how they work.
11th Oct 2010, 9:21 pm | #20 | |
Al
