UK Vintage Radio Repair and Restoration   Vintage Radio Service Data
Register FAQ Forum Rules Calendar Search Today's Posts Mark Forums Read
Reply
Old 29th Jul 2010, 02:25 PM   #1
TNC
TNC's Avatar
Default GEC Rescued
Grateful for any assistance to id this set which I have just liberated from the municipal tip for the cost of a pint.
It's a 20" b&w, the back has 405/625 aerial apertures but the 405 has not been opened and there is no 405 tuner or system switching so it looks to have been a late d/s model sold as only UHF.
As far as I can see it has 7 valves : PCL86, PFL200, PCL85, PCF802, PY88, PL504, DY87 and a selection of strange three-legged devices!
The crt is Mullard A50-120W/R.
There is a chassis no: G 1048517 and the single pcb carries the initials R.A.I.L. and the no PC 392A4.
Not sure if it's that interesting but it looked sad and unwanted so couldn't resist!
Trevor.
TNC is offline   Reply With Quote
Old 29th Jul 2010, 02:36 PM   #2
neil29
neil29's Avatar
Default Re: GEC Rescued
Probably a good save Trevor. as ive not seen any GEC dual standard or similar black & white sets from the late 60s early 70s ever . cheers neil..
neil29 is offline   Reply With Quote
Old 29th Jul 2010, 02:48 PM   #3
Alistair D
As far as I can remember the chassis is the GEC series 1.
The most common problem I used to have with them was lack of height at the bottom of the picture. This usually responded to replacing the resistor and cap on the cathode of the PCL85 pentode.
Al
Alistair D is offline   Reply With Quote
Old 29th Jul 2010, 03:32 PM   #4
BassoonBloke
BassoonBloke's Avatar
Thumbs up Re: GEC Rescued
Hello Trevor,
The other problem with this set is the double sided printed circuit board that tends to lift and cause a bit of a mess if you use too much heat soldering in one place (i think it was called the 'Fineline Series' but might well be wrong !).
Should work pretty well when working, i don't remember any really bad problems with these.
Cheers,
Alan.
BassoonBloke is offline   Reply With Quote
Old 29th Jul 2010, 04:52 PM   #5
murphyv310
murphyv310's Avatar
H Trevor.
I am sure that is a UHF 625 line single standard only set, It was a good chassis and much more reliable than the earlier versions.
A good find and quite rare now, probably more TV22's around than these.
Cheers,
Trevor
murphyv310 is offline   Reply With Quote
Old 29th Jul 2010, 05:02 PM   #6
pentode12
pentode12's Avatar
As Trevor said,
these were single standard UHF / 625 line sets that superceded the dual standard sets. The outward appearence and cabinets were practically identical on later production dual standard sets.
Andy.
pentode12 is offline   Reply With Quote
Old 29th Jul 2010, 05:59 PM   #7
TNC
TNC's Avatar
Thanks guys for your comments - it's v. encouraging to save something!
Does anyone have a model number? I have been trawing through Paul's TV circuits cd but can't seem to find it.
Thanks
Trevor.
Old 29th Jul 2010, 06:07 PM   #8
Tazman1966
Tazman1966's Avatar
Hi Trevor.
Here's another http://www.vintage-radio.net/forum/s...ead.php?t=9448
All the very best,
Tas
Tazman1966 is offline   Reply With Quote
Old 30th Jul 2010, 12:31 AM   #9
Hybrid tellies
Hybrid tellies's Avatar
Al
It is indeed the Series 1 625 line single standard mono set dating from the early 1970's. It was a very reliable chassis and gave a good account of itself. It is reasonably easy to work on but you need to treat that double sided print with care. This set is most certainly worth saving.
Simon
BVWS member
Hybrid tellies is offline   Reply With Quote
Old 30th Jul 2010, 08:56 AM   #10
The teleman
Hi Trevor , These are great little sets , I remember working on these when new, & i belive the model no to be 2048 series one chassis trader service sheet no 1957/t371 . good luck with the restoration , Chris..
The teleman is offline   Reply With Quote
Old 30th Jul 2010, 12:04 PM   #11
Welsh Anorak
Welsh Anorak's Avatar
Hi
There was also a Series Two which was almost the same - some had the controls and the speaker on the top of the cabinet - they used to fall inside with the heat.
A nice find - the very last GEC S/S hybrids were excellent sets as were the MS Deccas. Glad the controls are in one piece!
Glyn
Welsh Anorak is offline   Reply With Quote
Old 31st Jul 2010, 02:27 PM   #12
dazzlevision
Hello Trevor,
According to my GEC brochures of that era, the model number is 2047 (the single standard version of the equivalently styled 2043 dual standard set).
The green plastic label stamped “G1048517” is the serial number of the set (G = GEC - green label; S = Sobell – red label).
The initials “R.A.I.L.” stand for Radio & Allied Industries Ltd, the name of the "Sobell" firm before R&AIL amalgamated with GEC, circa 1961 (I think it would be called a “reverse takeover” nowadays). Michael Sobell started Sobell Industries in the 1940s, I believe and was soon joined by his son-in-law, Arnold (later Lord) Weinstock, who was closely involved with the merger of R&AIL with GEC.
These sets were available in a very similar looking dual standard version (model 2043) and their electrical design retained a lot of the circuitry used in their dual standard predecessors, such as the UHF tuner, line oscillator and frame oscillator/output stages. They did drop the PCL84 used in the dual standard sets as the audio output valve, opting for the more suitable PCL86.
I agree that the chassis is the Series 1 single standard mono chassis. It evolved into Series 2 (simpler mechanical construction) and then Series 3 (varicap tuning).
One stock fault that I remember is an open circuit 10MOhm 0.5W carbon composition resistor in the width stabilization stage, giving low width and boost HT.
Regards,
Dazzlevision
dazzlevision is offline   Reply With Quote
Old 31st Jul 2010, 10:17 PM   #13
TNC
TNC's Avatar
Thanks vm for model no. details and further fascinating info. - particularly wrt Lord Weinstock. I remember he was later famous (when Chairman of GEC) for refusing to spend a "in those days" massive company cash mountain of over £2.5bln despite the encouragement of politicians of all hues!
We could perhaps have done with a bit more of that in the last 10 years!
Trevor.
Old 3rd Aug 2010, 10:48 AM   #14
gec2110
These were nice sets and i think almost as good as the thorn 1500
and many of their rivals better than the philips 300 and bush A774
they do a model which is simlar but has all the controls on the top
looks in good nic hope the crt is ok as well
gec2110 is offline   Reply With Quote
Old 3rd Aug 2010, 12:07 PM   #15
murphyv310
murphyv310's Avatar
I would put them another way round, The Gec & Philips 230 series about equal and the A774 & 1500 not fairing quite as good
Cheers,
Trevor
Old 7th Aug 2010, 01:14 PM   #16
Vectamart
Vectamart's Avatar
Lack of height was often caused by the 1.5megohm resistor in series with the height control increasing in value.
Vectamart is offline   Reply With Quote
Old 7th Aug 2010, 04:08 PM   #17
Alistair D
Forgot about that one.
Al
Old 7th Aug 2010, 06:51 PM   #18
Hybrid tellies
I have had the height vdr go causing lack of height, the width resister and HT rectifier go but never had to replace the Loptx and never heard of one going either. All in all a great little set and probably the best after the ITT VC200 chassis.
Simon
BVWS member
Old 7th Aug 2010, 07:32 PM   #19
Tim
Tim's Avatar
And check anode and screen resistors too.
Yes and no(You're not wrong, I think it was called the fineline.)
Height problems are common on these caused by high value resistors. Best to clip out and solder new ones to the stumps, to avoid tracks lifting on that AWFUL board.
Tim is offline   Reply With Quote
Old 13th Aug 2010, 02:16 PM   #20
kipperdog
kipperdog's Avatar
If I remember correctly, GEC used double-sided printed circuit boards on quite a few models (and some other manufacturers as well) against advice of the day. The heat from the valves weakening the adhesive holding the track to the board. (Remember the CDA panel in the PYE colour TV?)
kipperdog is offline   Reply With Quote
Reply
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
All information and advice on this forum is subject to the WARNING AND DISCLAIMER located at http://www.vintage-radio.net.
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Copyright ©1997 - 2010, S&P Technology.
FIT Online Fashion Store - Now Open!
