Old 2nd Jun 2010, 3:54 pm   #1
PWH
Default Osram Four New Music Magnet
Hi could someone please advise the voltages for the supply
LT 2V
SG?
HT+
GB-
I can't find the circuit on disks 1-3 (as supplied by Paul.)
Thanks
PWH is offline
Old 2nd Jun 2010, 4:50 pm   #2
wireful3
Default Re: Osram Four New Music Magnet
I can't remember the specific voltages quoted for this set but The HT is almost certainly 120v. The SG is about 90v but 60v might also be OK. The GB will depend on the valve used but will probably be round about -3v or -1.5 volts. The original grid bias batteries had taps at 1.5 volt steps and I think the intention was to use trial and error. It would be less than 9v as this was the usual max voltage of the batteries.
The 9v batteries might even be later than the Music magnet, because it was normally used with a variable Mu valve as a volume control (RF gain)
wireful3 is offline
Old 2nd Jun 2010, 5:42 pm   #3
Boom
On the (3 valve) set I am playing with it has two grid bias battery connectors and from what I can see two is normal, one for the output stage and one for the earlier stage(s)
The bias volts are giving on the valve museum site if you are not sure.
Dave
Boom is offline
Old 2nd Jun 2010, 7:14 pm   #4
AC/HL
AC/HL's Avatar
MM4 installation Instructions part 1
Name:	Music Magnet 1.jpg
ID:	36594   Click image for larger version
Name:	Music Magnet 2.jpg
ID:	36595   Click image for larger version
Name:	Music Magnet 3.jpg
ID:	36596   Click image for larger version
Name:	Music Magnet 4.jpg
ID:	36597   Click image for larger version
Name:	Music Magnet 5.jpg
AC/HL is offline
Old 2nd Jun 2010, 7:21 pm   #5
AC/HL
AC/HL's Avatar
MM4 installation Instructions part 2
For some reason, they are uploading as thumbnails, not attachments. On my PC they can be read quite easily. If you PM your Email address, I'll send them direct.
Name:	Music Magnet 6.jpg
ID:	36599   Click image for larger version
Name:	Music Magnet 7.jpg
ID:	36600   Click image for larger version
Name:	Osram New Music Magnet 4.jpg
AC/HL is offline
Old 2nd Jun 2010, 9:04 pm   #6
Ed_Dinning
Hi PWH, just a note of caution. Do not adjust the GB tappings with the LT supply ON as this can damage the valves.
Ed
Ed_Dinning is offline
Old 3rd Jun 2010, 9:20 am   #7
PWH
Thank you all, I now have the information I need
For the reference of others HT is 120V, SG is 72-60V depending on volume (lower voltage = greater battery economy) GB is -9 to -3V as the LT battery dies away...
PWH is offline
Old 30th Aug 2010, 7:38 pm   #8
g3zilgwyn
Dear Bill
I've just come across your very helpful post. Having just written a short article for the BVWS Bulletin on the restoration of my Osram Four New Music Magnet, without the benefit of the pages you've scanned, I must recall my article and make some changes, even from what I can see in the thumbnails. Would it be possible for you to email me higher resolution scans?
In particular have you any comment on the "Super Power" P2 valve suggested as an alternative audio amplifier?
many thanks
Gwyn G3ZIL BVWS member
g3zilgwyn is offline
Old 31st Aug 2010, 7:24 pm   #9
AC/HL
AC/HL's Avatar
Hello Gwyn,
Send me your Email address by PM and I'll send by return.
Regards, Bill
PS as regards the super power valve it's just a more powerful triode as far as I know, hence the higher HT consumption. It was also popular to replace the last valve with a pentode at this time, necessitating replacing the four pin holder with a five.
AC/HL is offline
Old 1st Sep 2010, 5:54 pm   #10
g3zilgwyn
Bill
Many thanks. Will PM you my email address in a moment.
Thanks for the comment re the P2 super power valve. I had got confused, in that I remembered that a P2 was a bright emitter valve, but on delving deeper, this was a Cossor valve, and Marconi used P2 for their equivalent of the Mullard PM202.
The set was very confusing as I received it, for there was a KT2 in the output valve position, in a 5 pin socket, with the screen unconnected, and a 220OT in the detector position! But, all sorted now.
Would it be OK with you if I quoted from the material you've scanned in the article I've written for The Bulletin, I will of course credit you as the source.
regards
Gwyn
Old 3rd Dec 2015, 10:35 pm   #11
Daimlernut
Bill AC/HL I'm restoring an Osram 4 New Music Magnet, is there any chance of getting hold of the scans of the original instruction manual in high resolution as I can't read the ones on the forum very well - Alan
Daimlernut is offline
Old 4th Dec 2015, 12:47 am   #12
AC/HL
AC/HL's Avatar
Hi Alan,
PM your email address & I'll send what I have, I can't claim high res. but it is better.
AC/HL is offline
Old 4th Dec 2015, 1:20 am   #13
Andrew B
Andrew B's Avatar
Hi AC/HL Bill.
I am always interested in these older radios, could you PM me the manual etc please.
Andrew
worried about the electrons entering the circuit and the smoke leaving
Andrew
Andrew B is offline
Old 4th Dec 2015, 2:40 am   #14
AC/HL
AC/HL's Avatar
Of course Andrew, PM your email address.
AC/HL is offline
Old 4th Dec 2015, 4:35 pm   #15
Daimlernut
Many thanks bill for the higher resolution scans they are just what I need. - Alan
Old 12th Dec 2015, 1:48 pm   #16
Nungesser
Hi Bill,
I have just joined and have an Osram New Music magnet 4 without any instructions.
Could you send me some better resolution scans?
kind Regards
Dave
Nungesser is offline
Old 12th Dec 2015, 2:48 pm   #17
AC/HL
AC/HL's Avatar
Hi Dave,
As above, send me a PM with your email address.
AC/HL is offline
