Old 21st May 2010, 9:04 pm   #1
Heatercathodeshort
Heatercathodeshort's Avatar
Default Philips K35 26CS3890
I was presented this morning with a 26" Philips 26CS3890 receiver with Teletext and voice activated remote control. It is fitted with the K35 chassis and was the top of the range for 1983. This particular example is dated December 1983. It has a small internal printer that will print off onto paper a selected teletext page that is then ejected via a small slot on the front. The chassis is fitted with a mains isolation transformer as it is supplied with scart and din video/audio connection sockets.
The chassis is very complicated with an additional audio board together with all the remote control and teletext facilities. The receiver has never broken down and by the look of the thin dust I can well believe this. The tube system is the Mullard 30AX and is still capable of giving very bright pictures as can be seen from the camera shots.
The gentleman that presented me with the receiver showed great interest in the PYE V4 in my collection. He lived at Cambridge in 1953 very close to the Pye factory and purchased a V4 for the Coronation. He said it performed brilliantly with a huge outdoor aerial for many years. You had to have a sensitive set to pick up the AP signal that far out in those days!
I have never seen the Philips voice operated handset before and maybe after the Bank Holiday I will have a play with it. He also included all the paperwork which was very thoughtful of him. If there is any interest in this receiver I will post a few more pics. Regards, John.
ID:	36130   Click image for larger version
ID:	36131   Click image for larger version
ID:	36132   Click image for larger version
ID:	36133   Click image for larger version
Heatercathodeshort is online now
Old 21st May 2010, 9:17 pm   #2
murphyv310
Default Re: Philips K35 26CS3890
Hi John.
Never saw one of these up here, no doubt they wouldn't respond to the Scottish dialogue, Perhaps Billy Connolly programmed them for the Glasgow market!
Looks complicated but also seems to work well, nice interesting set to have though.
murphyv310 is offline
Old 21st May 2010, 9:25 pm   #3
Sideband
Sideband's Avatar
These were popular with the BBC and ITV news desks because of the teletext print facility. The voice activated remote is not original though. This was something of a novelty that Philips produced many years ago as a 'Universal' type. I'm not sure how good it was. I remember borrowing one when they were under review and the results were variable to say the least! It's so long ago, I don't even remember how you got it to react to spoken commands. I do know that they didn't like too much background noise otherwise some very odd things could happen.
They were improved at some point but I don't know how good the technology became.
As for the TV itself, K35 chassis with an improved audio output stage which, I think, drove a speaker within a bass-reflex enclosure. Very nice!
SB
'And, in the end, the love you take is equal to the love you make'
The Beatles.
Sideband is offline
Old 21st May 2010, 9:27 pm   #4
mark pirate
mark pirate's Avatar
Voice activated remote? looking forward to this thread
Mark
mark pirate is offline
Old 21st May 2010, 10:16 pm   #5
Jimmyhaflinger
Jimmyhaflinger's Avatar
We had this same model with built in printer in Italy but our version came with a regular remote (maybe it was just too expensive to make a voice control chipset that could understand Italian)
This set has a regular speaker without the bass reflex enclosure, which instead was instead used in the "cheaper" version without the printer and teletext modules.
By 1982, 30AX CRTs had been sorted out and no longer failed prematurely like the earlier examples from about 1979-81, actually, i think the "improved" version of the 30AX is one of the most durable tubes ever made
Jimmyhaflinger is offline
Old 21st May 2010, 11:07 pm   #6
chipp1968
chipp1968's Avatar
Interesting set to save for posterity. Like to se more .How it works
chipp1968 is offline
Old 22nd May 2010, 1:10 am   #7
repairman 1234
No Longer a Member
Very interesting set, there was one of these in our offered section a while back that i think ended up going to the skip!
repairman 1234 is offline
Old 22nd May 2010, 6:47 pm   #8
Heatercathodeshort
A few more pictures as requested. The teletext printer is shown in the 'pulled out' position for paper changing. I presume it's heat sensitive like fax paper.
The signal level fed into the set is very low arriving from around 30 miles away and being received on an aerial just 7ft off the ground inside the workshop roof section. Philips sets are very sensitive and could resolve a picture from an old dishcloth!
The extra 'voice commander' remote must be considered a novelty I think. It comes with a thick instruction manual but the previous owner said that it worked very well...EMMM I wonder? You have to 'teach' it your voice, Interesting. J.
Name:	K35 Front..JPG
ID:	36163   Click image for larger version
Name:	K35 remotes..JPG
ID:	36164   Click image for larger version
Old 22nd May 2010, 6:56 pm   #9
KeithsTV
KeithsTV's Avatar
Now there's a great temptation to train it, Shout CP and it tunes to X factor or something similar
Keith
KeithsTV is offline
Old 22nd May 2010, 7:27 pm   #10
murphyv310
Pity that when text goes after the analogue turn off this excellent feature will be redundant!
Old 22nd May 2010, 9:36 pm   #11
Sideband
Sideband's Avatar
Not sure you can get it anymore. It was a silvered paper using a thermal print head, very similar in operation to the original Sinclair printer for the ZX80/81.
SB
The Beatles.
Sideband is offline
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
Copyright ©2002 - 2017, Paul Stenning.
