UK Vintage Radio Repair and Restoration   Vintage Radio Service Data
Register FAQ Forum Rules Calendar Search Today's Posts Mark Forums Read
Old 12th Mar 2010, 09:17 PM   #1
nevann1
nevann1's Avatar
Smile Domino converter
Hi
I have an Aurora standards converter, and was wondering what the differences were between it and the Domino converter which I am thinking of getting.
It must be the London version as all my TVs are London versions.
Regards
Neville
nevann1 is offline
Old 12th Mar 2010, 09:30 PM   #2
murphyv310
murphyv310's Avatar
Default Re: domino convertor
Hello.
With the greatest respect why would you wish to swap an Aurora (with the exception of the early multistandard one less the inbuilt modulator)?
Cheers,
Trevor
murphyv310 is offline
Old 13th Mar 2010, 07:39 PM   #3
nevann1
nevann1's Avatar
Hi Trevor
I only have London sets and want to run several at the same time.
Regards
Neville
nevann1 is offline
Old 13th Mar 2010, 07:46 PM   #4
Sean Williams
Sean Williams's Avatar
Which you can do with an Aurora.....
It belts out so much RF a simple resistive splitter will allow you to supply atleast half a dozen sets with ease
Save Earth - C02 is bad, Humans make C02, we make more when exercising... Solution...BAN EXERCISE!
Sean Williams is offline
Old 14th Mar 2010, 08:02 AM   #5
murphyv310
murphyv310's Avatar
Hi Neville
Just a Sean says there should be no problem running a good few sets from an Aurora, without bringing down the Domino in any way I do feel though that the Aurora is a better converter, it's not far short of the broadcast Digital converters that were used up to the 405 switch off
Cheers,
Trevor
Old 16th Mar 2010, 07:05 PM   #6
Heatercathodeshort
Heatercathodeshort's Avatar
Default Re: Domino converter
Hello Neville, I am using an Aurora with a six way splitter with long cable runs [One is around 60ft long] and it still provides enough signal to operate relatively low gain sets. This can be extended even further if a simple aerial pre amp is employed. J.
Heatercathodeshort is offline
Old 16th Mar 2010, 09:31 PM   #7
nevann1
nevann1's Avatar
hi, many thanks to all for the advice . it appears the aurora has far more [ rf] output than i was led to believe. now the problem has been resolved. once again thanks to all kind regards neville
nevann1 is offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
All information and advice on this forum is subject to the WARNING AND DISCLAIMER located at http://www.vintage-radio.net.
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Copyright ©1997 - 2010, S&P Technology.
FIT Online Fashion Store - Now Open!
