Old 6th Feb 2010, 7:34 pm   #1
jazzy
jazzy's Avatar
Default 8 diode bridge rectifier?
Hello
I have a old rf valve amplifier which has 8 diodes what make up a bridge rectifier circuit, i don't think this is a doubling circuit.
Why then has 8 diodes been use instead of the usual 4 ?
Thany you
Garry
jazzy is offline
Old 6th Feb 2010, 7:45 pm   #2
valvekits
Default Re: 8 diode bridge rectifier?
Garry
I think this might be a way of increasing the Peak Inverse Voltage rating, assuming that there are four pairs of series connected diodes.
Eddie
valvekits is offline
Old 6th Feb 2010, 7:52 pm   #3
Michael Maurice
Michael Maurice's Avatar
I assume the diodes are semiconductors. It is indeed a way of doubling the PIV, i've seen this used in several applications.
Michael Maurice is offline
Old 6th Feb 2010, 8:03 pm   #4
jazzy
jazzy's Avatar
Thank you both for getting back to me ,yes there are two set of 4 diodes next to each other. I replaced them for higher rating as the first set fouled (was 500v now 1000v)
Thank you again
Garry
jazzy is offline
Old 6th Feb 2010, 8:09 pm   #5
jazzy
jazzy's Avatar
Just a thought why not just use higher rated diodes instead to increasing the Peak Inverse Voltage rating And why the need?
jazzy is offline
Old 6th Feb 2010, 10:43 pm   #6
G8HQP Dave
How old is it? Early semiconductor diodes did not go to high voltages, so doubling up was quite common.
G8HQP Dave is offline
Old 7th Feb 2010, 10:35 am   #7
Sideband
Sideband's Avatar
Indeed! It was not uncommon to use two semi-conducter diodes in series for just a simple half-wave rectifier. The early diodes did not have the high PIV of later types. With a bridge rec, there would quite often be two diodes in series on each 'leg'.
Rich
'And, in the end, the love you take is equal to the love you make'
The Beatles.
Sideband is offline
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
Copyright ©2002 - 2017, Paul Stenning.
