UK Vintage Radio Repair and Restoration   Vintage Radio Service Data
Register FAQ Forum Rules Calendar Search Today's Posts Mark Forums Read
Old 22nd Sep 2008, 10:16 AM   #1
petervk2mlg
petervk2mlg's Avatar
Default Lux amplifier transistor replacement
I just bought a faulty Lux SQ77T/II
On investigation there was a blown 2 amp fuse on the secondary side of the transformer.
I traced the fault to one of the output transistors - an SD 119 which had a base to collector short.
Each channel has a pair of 2SD119s as the final transistors.
I replaced the faulty transistor with a 2N3055. Will this be OK or should I replace all the transistors with the same type?
peter
petervk2mlg is offline
Old 22nd Sep 2008, 10:24 AM   #2
SaSi_SiDi
Default Re: Lux amplifier transistor replacement
I think that replacing all 4 would be more prudent. It all depends how close a match the 2N3055 is to the 2SD119.
SaSi_SiDi is offline
Old 22nd Sep 2008, 10:51 AM   #3
studiot
Your main problem is likely to be the higher frequency response of modern transistors introducing unwanted instability.
This amp is not compensated for these.
The 2SD119 has a modest Ft of a few hundred kilohertz, as do older 3055s, but more modern 3055 go higher.
I should avoid MJXXX TO3 transistors are they are good for several Mhz.
BDX XX eg BDX20 will probably do as they are limited to .8 Mhz
Nearer 2N equivalents are 2N3442 and 2N3773.
I should certainly substitute in pairs at least.
studiot is offline
Old 22nd Sep 2008, 04:16 PM   #4
Mike-repairman
Mike-repairman's Avatar
If just replacing the output transistors does not cure the fault I would suggest replacing all the 5 transistors after the audio coupling capacitor, 10mfd 25V.
As the circuit is DC coupled the driver transistors could be leaky of have been hammered when the output ones failed.
Failure to do this may result in damaging the new output ones again.
Mike.
Mike-repairman is offline
Old 23rd Sep 2008, 10:55 AM   #5
petervk2mlg
Thanks guys.
I have some more work ahead of me, then.
Peter
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
All information and advice on this forum is subject to the WARNING AND DISCLAIMER located at http://www.vintage-radio.net.
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Copyright ©1997 - 2010, S&P Technology.
FIT Online Fashion Store - Now Open!
