Old 3rd Jan 2007, 11:14 am   #1
oldeurope
oldeurope's Avatar
Thumbs up making an audio output triode...
Searching for a power triode, I found a way to multiply the current of a small signal triode (ECC82) by a transistor (BU4525AXPH selected B=10).
Generally the output side of a transistor is similar to a pentode, but connected in the way shown in the pictures it is exactly like a triode. In this application modern bipolar transistors are making an output current B- times higher than the base current independent of the Collector – Emitter voltage. Bipolar power NPN transistors with a B from 5 to 50 and up to 1500V peak C-E Voltage are available. So you can make your dream audio output triode with the perfect characteristic of a small signal triode multiplied by current gain factor B. The transistor is a kind of triodemultiepler. For the test arrangement Rk = 270 Ohms Ua = 300VDC (Ug = -16V, Ia = 60mA) Ra = 2K5 Ohms gives something about 3 Watts audio output.
Happy experimentig,
Darius
Name:	ausgangskennlinienfeld triode.png
ID:	7529   Click image for larger version
ID:	7530   Click image for larger version
oldeurope is offline
Old 3rd Jan 2007, 11:23 am   #2
peter_sol
Default Re: making an audio output triode...
Hi
A circuit diagram would be welcome.
Peter.
peter_sol is offline
Old 3rd Jan 2007, 11:29 am   #3
ppppenguin
ppppenguin's Avatar
The circuit is sketched on the graph.
It looks like a darlington pair with the first transistor replaced by a valve.
The audiophools will never buy it becuase it's got unmentionable silicon fuses in it
ppppenguin is offline
Old 3rd Jan 2007, 12:43 pm   #4
oldeurope
oldeurope's Avatar
Yes, but I think there are a lot of more technical audioenthusiasts who want to build and test ist. It is so easy and the result is perfect. I tried to find something similar at google but I didn't. Often you find something infront of a transistor amp to get triode sound. This is definately not the same!
Darius
Old 3rd Jan 2007, 1:24 pm   #5
oldeurope
oldeurope's Avatar
Smile Re: making an audio output triode...
typical application circuit attached:
Old 3rd Jan 2007, 3:35 pm   #6
oldeurope
oldeurope's Avatar
Talking Re: making an audio output triode...
@Jeffrey, what do you think about the following names:
triodemultipler, valvelington, tubelington, triodelington?
Other suggestions are welcome, hi hi.
Darius
Old 3rd Jan 2007, 4:07 pm   #7
mickjjo
mickjjo's Avatar
The Transiodarius .
Regards, Mick.
mickjjo is offline
Old 4th Jan 2007, 2:15 am   #8
adibrook
adibrook's Avatar
Hmm....i like this.
So, techically, a small triode and a massive transistor can be used to give lots of power.
Nice idea!!!
adibrook is offline
Old 4th Jan 2007, 8:51 am   #9
oldeurope
oldeurope's Avatar
I will use both systems of the ECC82 in parallel. Than the circuit is equal to eleven (!) ECC82 in parallel. Each triode system of the ECC82 has about 5mA at 250- 300V so long live is guaranteed. This will give 5W or a bit more. Enough for a triode amp. The power dissipation will be about 25W. Next week I'll make some nice output transformers for this triode multipler arrangement.
Hi adibrook, only 20% from the dissipated power comes to the speaker. So a triode is not an economic way to get a lot of power.
Darius
Old 4th Jan 2007, 9:26 am   #10
Mike Phelan
Mike Phelan's Avatar
Almost like some of the old car radios that had E??83 12 volt HT valves and an OC16 for output! Except they were not direct coupled.
Mike.
Mike Phelan is offline
Old 4th Jan 2007, 10:43 am   #11
oldeurope
oldeurope's Avatar
Unhappy Re: making an audio output triode...
Oh dear, sorry, there is a misunderstanding.Driving a transistor with a valve (triode) DC coubled or not doesn‘t create a triode output in general!
It is the special arrangement I showed above that makes the triode output.
Kind regards,
Darius
Old 4th Jan 2007, 10:58 am   #12
Merlin
Merlin's Avatar
Wow I really like this idea! I suppose it'd work with a small signal pentode too right? If you set the screen up right.
What kind of transistor is that anyway? How would you go about choosing an equivalent if you couldn't get your hands on that one?
Merlin is offline
Old 4th Jan 2007, 11:13 am   #13
oldeurope
oldeurope's Avatar
You mean screen and anode parallel = triode?
Darius
Old 4th Jan 2007, 12:01 pm   #14
Merlin
Merlin's Avatar
Um, well for normal triode operation you'd connect the screen directly to the anode. I was thinking of running the screen separately as in normal pentode operation. The transistor would then amplify its characteristics and you'd have a power pentode? I may of course has misunderstood this whole idea!
Merlin is offline
Old 4th Jan 2007, 12:25 pm   #15
oldeurope
oldeurope's Avatar
Hi Merlin,
a transistor and a pentode do have the same output characteristics.
And there are a lot of nice pentodes available, so this makes no sense to me.
If you connect the plate of the driving triode to a fixt positive voltage the arrangement has the same characteristics at input and output like a pentode.
I want to have a (power) triode.
Darius
Old 5th Jan 2007, 10:48 am   #16
Merlin
Merlin's Avatar
Well I was thinking you'd be able to get the characteristics of the small pentode (which sounds nicer than a transistor), but be able to use it as a power pentode. So it'd sound like a pentode and not like a transistor...
Incidentally, hot were you thinking of setting this up as an output stage? With an output transformer between HT and the anode/collector as usual?
Here are some more names too, "valvistor", "triistor" (or tri-istor), "tristor"!
Merlin is offline
Old 5th Jan 2007, 3:29 pm   #17
oldeurope
oldeurope's Avatar
Yes, as usual.
Old 8th Jan 2007, 10:41 am   #18
Merlin
Merlin's Avatar
I've only just noticed you posted a typical circuit above. What is the zener diode for? Surely the ECC82 doesn't need protection from overvoltage?
Merlin is offline
Old 8th Jan 2007, 3:19 pm   #19
oldeurope
oldeurope's Avatar
It is to make sure that there isn't more than 1000V at the plate/collector.
Darius
Old 8th Jan 2007, 8:01 pm   #20
cathoderesistor
Great work, Darius.
Have you carried out any distortion analysis? Power Triodes produce mainly
2H ofcourse.
cathoderesistor is offline
