Old 25th Aug 2006, 5:14 pm   #1
Kat Manton
Kat Manton's Avatar
Default FothTV (405-line from a PC) - KISS Circuit
I've been pondering the complexity of the MkII RGB combiner, trying to come up with something simpler and consequently easier and quicker to lash up.
This is the end result, it uses the smallest number of parts I think it's possible to get away with while still "working".
This just crudely adds composite sync to the green video signal, ignoring red and blue. I've tried it with monochrome and colour DVDs and it works pretty well, considering. Field-sync is just one broad pulse which my fussy Pye monitor doesn't like, I get line-pairing as happens with the XORed syncs from the "MkII". But I do get a locked 405-line picture. Well, sort of...
I'm not sure what a VHF modulator will make of it, though; I've still not built one.
But, here it is - it could be worth trying this first, then work up to better circuits later
Code:
         | | 47uF
GREEN ___| |_________________________
                             680R    |
HSYNC ___________       ___/\  /\  __O___ GREEN + CSYNC
                 \    _/     \/  \/
                    | 2N3904
           1k0      |
VSYNC ___/\  /\  ___|
(I'm not claiming originality; I found a few circuits for feeding "Sync on Green" monitors while trawling the 'net for ideas, this is a rip-off of one of them...)
So... you need this, a suitable PC and a modulator...
I should add that this requires both syncs to be negative-going, so you need "-hsync -vsync" in the modeline.
Regards, Kat
Voider of Warranties.
Last edited by Kat Manton; 25th Aug 2006 at 5:23 pm. Reason: Added note about modeline
Kat Manton is offline
Old 25th Aug 2006, 5:28 pm   #2
jim_beacon
jim_beacon's Avatar
Default Re: FothTV (405-line from a PC) - KISS Circuit
Hi Kat,
I've been toying with this kind of idea for a while (also prompted by a web search). Is there any reason why the RGB signals can't be mixed with resistors? It would then at least approximate a monchrome signal (OK, so it may up the parts count by 6).
Jim.
Jim Beacon G1JBG
www.g1jbg.co.uk
jim_beacon is offline
Old 25th Aug 2006, 5:32 pm   #3
Kat Manton
Kat Manton's Avatar
Hi Jim,
Nope, no reason at all; now I've proven this one works; guess what I'm lashing up right this minute?
Regards, Kat
Old 30th Aug 2006, 7:10 am   #4
oldeurope
oldeurope's Avatar
Originally Posted by jim_beacon View Post
Hi Kat,
Jim.
Hi Jim, you need only three additional resistors.
Place a 180R at red , 680R at blue and 47R at green.
Connect them at the 47uF.
Darius
RADIO & TV SERVICE
oldeurope's blogs
oldeurope is offline
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
Copyright ©2002 - 2017, Paul Stenning.
