18th Aug 2010, 5:34 pm | #1 |
Avometer model 8 not functioning.
I have a Avo 8 Mk 5, the one with plastic connection leads internally, it won't work on any of the DC volts ranges, all other ranges OK. Any help would be appreciated.Ted
18th Aug 2010, 8:19 pm | #2 |
Re: Avometer model 8 not functioning.
The obvious suggestion is to check the mylar flexi. They are notorious for going open circuit, sometimes in a very intermittent way.
Buzz them through with another meter, breaks can be invisible.
Kevin |
24th Aug 2010, 1:03 pm | #3 |
A good way to look for hairline cracks is to shine a bright light through from t'other side. I find a tiny LED 'keyfob' torch very useful for getting into awkward places.
Roger |
24th Aug 2010, 5:21 pm | #4 |
Many thanks to all who responded to my request, fault located and its working on all ranges as it should.Just a slight problem with a switch.Having been inside earlier models was amazed how little was in the later Mk.
