Old 19th Jun 2017, 11:39 am   #1
Tractorfan
Tractorfan's Avatar
Smile Using an electronic transformer for a model tram motor?
A good friend has asked me to make a speed controller for the 12 volt DC motor in his model tram which will run on just a few metres of track.
I've found a simple, two transistor speed controller, and am thinking about powering it with an electronic transformer intended for halogen lamps. It is a high frequency AC device, and I'm pondering how to rectify & smooth it with bits from my junk-box. Would I need special diodes for the HF? or would IN4002s be OK at that frequency (maybe around 15Khz?)?
If not, I could use the 'traditional' 12 volt transformer from a scrap halogen desk lamp instead.
Thanks.
Pete.
Tractorfan is offline   Reply With Quote
Old 19th Jun 2017, 12:04 pm   #2
astral highway
astral highway's Avatar
Default Re: Using an electronic transformer for a model tram motor?
Hello,
That seems a lot of effort for a simple 12VDC supply; how about any old Walwart 12V supply?
If you want to go the other route, 15KHz is far too high to be a suitable frequency for the 1N400X series to deal with, they're general purpose rectifier diodes more suited for mains frequency. You could use Schottky diodes, instead.
Al
astral highway is offline   Reply With Quote
Old 19th Jun 2017, 12:10 pm   #3
Refugee
Refugee's Avatar
UF400X diodes are what you need.
I looked into model control some years ago and came to the conclusion that the current the motor takes can be used to control absolute speed and provide a speed indicator on the controller.
The motor produces a current waveform that can be measured.
Refugee is offline   Reply With Quote
Old 19th Jun 2017, 12:40 pm   #4
broadgage
Standard rectifier diodes wont work with the very high frequency AC from an electronic transformer.
I would use copper iron transformer, or possibly an electronic transformer with DC output.
DC units are readily available as some types of 12 volt LED lamp require or prefer a DC supply.
broadgage is offline   Reply With Quote
Old 19th Jun 2017, 12:42 pm   #5
russell_w_b
russell_w_b's Avatar
Best of luck... Here's what the output of an electronic transformer meant for powering halogen lamps looks like.
http://www.vintage-radio.net/forum/s...1&postcount=42
Regds,
Russell W. B.
G4YLI.
russell_w_b is offline   Reply With Quote
Old 19th Jun 2017, 3:19 pm   #6
Tractorfan
Tractorfan's Avatar
Smile Re: Using an electronic transformer for a model tram motor?
Hi and thanks for your speedy replies,
I had a sneaky feeling that 1N4002 might not be suitable but wasn't certain .
I could use a wall wart, but seeing as I had a box full of electronic transformers and few wall warts of any use (or with European pins instead of UK ones, which is where the project is destined), I wanted to use what was to hand.
Not to worry, I have a halogen desk lamp that I can rob the iron/copper transformer from.
Thanks again,
Pete.
Old 19th Jun 2017, 7:24 pm   #7
thermionic
thermionic's Avatar
Good call...! Trying to rectify the output from a halogen transformer is fraught with problems. In addition to the points above, they won't output any voltage until they are loaded. Therefore, you would need to introduce a load on the AC output, before rectification...
SimonT.
The honesty of imperfection..........
thermionic is offline   Reply With Quote
Old 19th Jun 2017, 9:48 pm   #8
winston_1
There is no such thing as an electronic transformer, it is a made up term by manufacturers or distributers who don't know what a transformer is. (A device which changes voltage or current by magnetic induction, [or doesn't in the case of isolation transformers]).
Electronic halogen lamp drivers are a (poor) form of switch mode power supply which need a minimum load to work. No way can you rectify and smooth the output as you desire.
winston_1 is offline   Reply With Quote
Old 20th Jun 2017, 10:07 am   #9
Tractorfan
Tractorfan's Avatar
I realise that it's not a 'transformer' per se, but I used the term to differentiate it from a 'proper' transformer. Indeed, it's a 'driver'.
Cheers, Pete.
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
Copyright ©2002 - 2017, Paul Stenning.
