14th Mar 2017, 5:30 pm | #1 |
Smoothing choke replacement
Please could I have some advice on a replacement part for a 160 m 2h smoothing choke . Could a use a resistor ? if so what resistance would be best ? Or is there a modern replacement part ?
thanks keith |
14th Mar 2017, 6:01 pm | #2 |
Re: Smoothing choke replacement
How about using a Hammond 157R. Available from Bluebell Audio. Look under Transformers, then Choke:-
http://www.bluebellaudio.com/
15th Mar 2017, 1:52 pm | #3 |
Depends on the circuit. If all the HT comes off after the choke, a resistor of the same value as the choke's dc resistance followed by a much larger capacitor than original would probably work fine. If the rectifier can stand it, up the reservoir cap value as well.
15th Mar 2017, 7:51 pm | #4 |
Hi the rectifier valve is a U52 16mfd cap them the choke (burnt out) then 16mfd cap its only a old film projector amp so I but of sound loss and humm is ok as optical sound is no hi fi
keith |
