Old 4th Dec 2016, 9:02 pm   #1
peter.sables
peter.sables's Avatar
Default All World two help.
hi
I'm about to put the parts together to build the All WORLD TWO. Only I need help with the coil for it. Dia - turns swg.
please help.
Pete G4MRU
hI Again.
I've been looking at the information on here.. Good but nothing about the coils...
pete
peter.sables is offline
Old 4th Dec 2016, 10:57 pm   #2
David G4EBT
David G4EBT's Avatar
Default Re: All World two help.
There's a 73-page paper by Gerry O'Hara at the Eddystone User Goup on the 'All World Two' at the link below Peter, but originally the coils were off-the-shelf Eddystones, so unless you can find the data about those coils, that's not a lot of help. Undoubtably others will have built replicas, so if no-one on here can add anything, you might like to try your luck on the EUG:
http://eddystoneusergroup.org.uk/Res...Appendices.pdf
Hope that helps a bit.
Good luck in your quest.
David.
BVWS Member.
G-QRP Club member 1339.
David G4EBT is offline
Old 4th Dec 2016, 11:21 pm   #3
Some info here for some coil turns, no diameter given as far as I can see but should be able to work out/guesstimate ?:
http://www.vintageradio.me.uk/kits/eddy_allwave.htm
Old 5th Dec 2016, 12:07 am   #4
peter.sables
hi.
thats good. I can make a start with that.
pete G4MRU
Old 5th Dec 2016, 12:00 pm   #5
60 oldjohn
Hi Pete, I have this 1.5" D coil, Looks like its the same former on the above Eddystone page with 6 pins, marked "RAYMART MFC CO BIRMINGHAM" Box is marked looks like "281L coil for radio" or may be price 28/4 but that would be very expensive for the year. Yours for postage if needed.
John.
ID:	133841   Click image for larger version
60 oldjohn is offline
Old 5th Dec 2016, 5:21 pm   #6
peter.sables
HI.
Yes please. That's brilliant
Pete G4MRU
Old 26th Dec 2016, 9:58 pm   #7
JohnBG8JMB
Hi Pete
Dia is 1 3/8"
all the info can be found on http://www.eddystoneusergroup.org.uk/
I've attached a pic of the data, I hope
I need a 10x14 pf step bandspread tuning cap 'tank unit 1042' for a similar project [amateurs SW2][
G8JMB
JohnBG8JMB is offline
Old 12th Mar 2017, 5:21 pm   #8
VE3AWA Lou
Hello Pete,
Are you using Eddystone formers and did you find the turns count information you needed?
73, Lou VE3AWA
VE3AWA Lou is offline
Old 13th Mar 2017, 12:33 am   #9
Bazz4CQJ
Bazz4CQJ's Avatar
I wonder which is better; an "All World Two" or an "International Shortwave Two" (for latter see http://vintageradio.me.uk/radconnav/2_valve.htm) ?
Perhaps we should ask Harry Hill?
Some similarity of coils?
B
Bazz4CQJ is online now
Old 24th Mar 2017, 10:30 pm   #10
peter.sables
hi.
I have finished the All World Two. People keep asking is it any good. I must say I've built better. Its all down to getting used to the band spread. In mine I used a modern tuning capacitor. Trouble is the are not linear, so the band spread is not linear. not good.
Pete
ID:	139766   Click image for larger version
ID:	139767   Click image for larger version
Old 25th Mar 2017, 9:25 am   #11
Bazz4CQJ
Bazz4CQJ's Avatar
Given the limited degree of selectivity of a two valve TRF, and if you have some decent slow-motion drives, I'm a little surprised that you need bandspread, at least for broadcast stations. The "Int. SW 2" didn't have bandspread. Perhaps those Eddytone formers really do make super Hi-Q coils .
B
Old 25th Mar 2017, 10:03 am   #12
What's the value of the bandspread capacitor you used?
Old 25th Mar 2017, 10:48 am   #13
Here's a good article on regens from 1933:
http://www.rfcafe.com/references/qst...y-1933-qst.htm
Old 27th Mar 2017, 10:50 pm   #14
peter.sables
hi
That is the problem. Ha the band spread is 25pf.
pete
ID:	139954   Click image for larger version
