23rd Feb 2009, 6:21 pm | #1 |
Choke use as dropper
Hi all
I have used a 25R large wattage resistor in the past to drop the UK mains voltage to accommadate a chinese transformer rated at 220 volts ac , my question is would it be possible to use a choke which would give you that same resistance so it would do the job much better without the excessive heat generated by a dropper resistor. Acorn |
23rd Feb 2009, 8:49 pm | #2 |
Re: Choke use as dropper
I'd be a bit careful, if the choke saturates through too much current it will revert to being a low value resistor...
23rd Feb 2009, 9:12 pm | #3 |
Best method by far is a suitably rated auto transformer, mains to 0-240V winding and amp to 0-220V Tapping. Though my Chinese amp was labelled for 220V I found the heater voltage well down on the auto transformer but came up to 6.3V with direct mains input. It has been running fine for the last two years, I think I was lucky in having an amp with a suitable UK rated transformer. I have however seen on the internet some sorry tales about other makes of Chinese amplifiers getting fried on our mains supply through having no correction applied. The heater voltage measurement seems to be a good indicator.
Whether the Top Cap is Grid or Anode - touching it will give you a buzz either way! |
23rd Feb 2009, 11:19 pm | #4 |
Hi
You can use a 240 - 20V transformer. Connect the mains side to mains, and the 20V side in series with the 240V i/p to your amp. You have to make sure you get the phasing the right way around, one way it will add 20V and the other way subtract 20V. I have seen this system used in 220V refrigeration gear sold in the UK. The transformer 20V needs to be rated at the same current as the amp is going to draw + a bit.
BVWS member. |
24th Feb 2009, 12:32 am | #5 |
An alternative to a resistor is to use a capacitor in series. This gives "wattless" voltage dropping so no heat. You will however have to experiment with the value but it will be of the order of a (few?) mfd I would guess. It must have good insulation and must not be an electrolytic. There is an article somewhere a few years ago about how to go about calculating the value required but I cannot recall where. I have used this technique for a number of items, probably the most common being to reduce the speed of cooling fans to cut down the noise.
Pat G3IKR |
24th Feb 2009, 12:38 am | #6 |
A 100W bulb will typically drop about 20V. You can put it in an external box with a European socket for the '220V' output.
Paul |
24th Feb 2009, 3:14 pm | #7 |
Hello acorn,
what does that "chinese transformer" drive? Is the load constant or variable? Is this a transformer for use in China or is it a transformer for export to Europe? Without this data one can only guess what to do. Regards Georg |
24th Feb 2009, 6:19 pm | #8 |
Thanks lads,
Plenty food for thought I like the capacitor idea but what kind of cap and what value to use I expect it would have to be a 5uF solid state poly type rated at 300 volts ac at least to take care of any spikes in the AC supply. Hi George , it would be for a Chinese import to the UK rated with a 220 ac input. Acorn |
25th Feb 2009, 3:20 pm | #9 | |
You do not know the importance of it. One needs the power rating of the transformer and the actual power load from the transformer. Without that any fantasy like capacitors or chokes is possible. If there is a label on the transformer, tell us what is written on, or, better post a picture. In general, either nothing is needed, or a resistor, or the 20 Volts transformer. Capacitors or chokes are not the usual solution exept in cases of very small power. Georg |
25th Feb 2009, 6:35 pm | #10 |
Use a say a 240 V to12.6 volt filament transformer and wire the 12.6 volt winding in series with the '240 VOLT" input of the chinese transformer but in anti phase to change the input to the chinese transformer to be your mains less 12.6 volts. Make sure that the filament transformer is antiphase and not aiding!
John. |
