Old 23rd Mar 2014, 10:33 pm   #141
davidgem1406
davidgem1406's Avatar
Default Re: Tektronix 465B Scope - Some problems.
Hi Bill,
Didn't think about that one.
I did use the Advance SG63 HT rail and by selecting the stabilizer valves got it to 215V after it had warmed up nicely.
I used a string of 5 x 10Meg and as your suggestion a 1Meg as the resistor in parallel to the DMM.
Using 2 DMM's (Both 10Meg at the input) I used the Fluke to read the attenuated voltage, whilst the other monitored the HT rail.
I ended up with a conversion factor of 215/3.74 that I worked backwards to get the value that would be expected on the DMM for the 2450V.
2450/215 x 3.74 = 42.61V at the DMM
42.61 x 215/3.74 = 2449.50V
Just as interest that says that to obtain a maximum reading of 1000V on the DMM it would need 23KV. NO, I wont be trying it.
The thing that comes to mind now is that the voltage across each 10Meg resistor is way above the specification of the resistors at 500V each.
I think I will make it a string of 10 resistors at least it will half the voltage across each of them.
I will add the 5 resistors, see what it then gives, and then look at making it up into a usable probe.
Dave.
davidgem1406 is offline
Old 23rd Mar 2014, 10:57 pm   #142
maninashed
Dave, its overkill. Normal resistors will be fine for short periods, its usually if there is any damp or you are using over a prolonged period that they will break down. For a minute or so you will be fine with that setup. If I were you, I wouldn't try to measure the multiplier output to the final anode, the noise will put you off ! Just set the cathode volts to spec and that should do, the final anode voltage should be ok if no components have been changed. 1 watt or 2W resistors generally have a higher voltage handling capability if you want some piece of mind.
Bill
maninashed is offline
Old 24th Mar 2014, 3:53 pm   #143
davidgem1406
Hi Bill,
I have now made the probe and done a final check on it and all is OK.
I did add the extra resistors, I just felt happier about doing that and I had room available to allow for it.
The additional resistor produced a multiplication factor of DMM Reading x 216/1.9
I used the empty canister from a large bullet point marker with the inside removed it was ideal. Some pictures added.
Now I will make a check on the cathode voltage and see what difference that may make.
Dave
ID:	90574   Click image for larger version
ID:	90575   Click image for larger version
Old 25th Mar 2014, 12:28 am   #144
davidgem1406
I have now checked the cathode voltage and it is within the spec limits at 2458.98V
3 pictures have been added showing details of the spot. The original pictures were quite large so I copied out the center section so that the details of the spot can be seen.
The brightness may seem as though it is a bit high but actually is not, it is set at a level that if a high speed trace is switched in you cant even see it.
Picture 1 is the spot with best focus I can obtain. 2 is the focus turned right, and 3 turned left.
All in all I still think it has a problem, maybe the replacement tube is not much better than the original??
Dave.
ID:	90608   Click image for larger version
ID:	90609   Click image for larger version
