Old 15th Jan 2012, 5:00 am   #61
mrmagnetophon
Default Re: AKG C60 valve mic
Still attempting to fix the problem, everything is spot on with the mic and the schematic.
The ground lift switched don't seem to change the problem, it still hums.
-Chris
mrmagnetophon is offline
Old 21st Jan 2012, 7:48 am   #62
mrmagnetophon
I went to a new mixing console to test, and wow, huge difference, most of the hum is being rejected, its kinda distorted hum now, like a WAH sound, if that makes sense?
-Chris
Old 22nd Jan 2012, 7:39 am   #63
mrmagnetophon
Another huge breakthrough and progress forward!
I removed the ground wire of the transformer, (one from the transformer running to ground for the input side) and wow still humming, so I doubt now that it's the body of the mic causing a problem.
-Chris
Old 4th Feb 2012, 11:06 pm   #64
mrmagnetophon
Now I'm back at it, removed the signal wire from the transformer and it's still humming. The problem somehow seems to be maybe a induced voltage into the transformer not sure here.
-Chris
Old 5th Feb 2012, 12:50 am   #65
mrmagnetophon
After moving the output transformer from the power supply to an external box, I noticed a reduction in hum,10 fold, although it's still there slightly but not by much.
-Chris
Old 6th Feb 2012, 4:06 am   #66
mrmagnetophon
Should the chassis be connected to ground, or is using negative (combined ground) from the power supply fine?
Somewhere its gotta be picking up noise from having the power supply hooked up.
-Chris
Old 6th Feb 2012, 5:17 am   #67
mrmagnetophon
Used batteries and supplied around 45 volts for HT, batteries became warm, but this time, it produced static for sound?!?! almost like a untuned radio?!?!
Old 10th Feb 2012, 4:45 am   #68
mrmagnetophon
Its a low amount of hum, very small amount only heard when turning the volume all the way up, no other sound passes though.
