Old 22nd Aug 2011, 12:05 pm   #1
FERNSEH
FERNSEH's Avatar
Default Bush TV12 restoration.
Let's see if I can get this set working before the weekend.
The results so far are a narrow thin horizontal line and an indicated 4KV EHT.
DFWB.
ID:	55375   Click image for larger version
FERNSEH is offline
Old 22nd Aug 2011, 12:08 pm   #2
Andy Doz
Andy Doz's Avatar
Default Re: Bush TV12 restoration.
I'll race you .. I've got a TV22 just arrived. Not powered it up yet , but I'm hoping the LOPTx is OK, so the line whistle will drive away the woodworm in the side panels
Andy Doz is offline
Old 22nd Aug 2011, 12:52 pm   #3
FERNSEH
FERNSEH's Avatar
Originally Posted by Andy Doz View Post
I'll race you ......
OK the challenge is on.
David.
FERNSEH is offline
Old 22nd Aug 2011, 3:49 pm   #4
Peter.N.
I would turn the brightness down on that!
Peter
Peter.N. is offline
Old 22nd Aug 2011, 3:58 pm   #5
FERNSEH
FERNSEH's Avatar
Following my policy of Glasnost (openess) I can report that the line timebase has packed in.
DFWB.
FERNSEH is offline
Old 22nd Aug 2011, 4:27 pm   #6
Heatercathodeshort
Heatercathodeshort's Avatar
No excuses allowed! As soon a a challenge rears it's head you creep back into the workshop! I'm backing you David. Don't allow the TV22 brigade to intimidate you. .
The EHT on a TV12 is rarely above 4.9kv unless it is fitted with the later line output transformer. It still gives a good picture even with this very low EHT potential. Boost cap and coupling caps come to mind. It was a good first light. Pity the bulb in the lighthouse popped just before you crashed into the rocks.
Even with that minimum display it shows a good CRT and LOPT, the rest is easy. Regards, John.
Heatercathodeshort is offline
Old 22nd Aug 2011, 4:44 pm   #7
murphyv310
murphyv310's Avatar
Has war broken out in the vintage community?
Cheers,
Trevor.
MM0KJJ. RSGB, GQRP, WACRAL, K&LARC. Member
murphyv310 is offline
Old 22nd Aug 2011, 4:58 pm   #8
FERNSEH
FERNSEH's Avatar
Hi Trevor,
Not exactly war, let's say a difference of opinion. Eine Meinungsverschiedenheit
TV12 versas TV22, no competition. Everyone knows which is the better set.
DFWB.
FERNSEH is offline
Old 23rd Aug 2011, 8:04 am   #9
Andy Doz
Andy Doz's Avatar
... it's just I happened to have a TV22 to do at the same time ...
I can confirm my line stage doesn't work either, the top cap's fallen off my line bottle..
Andy Doz is offline
Old 23rd Aug 2011, 8:16 pm   #10
Andy Doz
Andy Doz's Avatar
A few caps. Repair the top cap on the line output valve ... and up with the volts!!
... there's all to play for.
Andy Doz is offline
Old 23rd Aug 2011, 9:45 pm   #11
audiomagpie
audiomagpie's Avatar
Nice to see the tube 'smiling'!
You know you're well on your way at that stage!
Greg
Greg
BVWS committee chairman
audiomagpie is offline
Old 23rd Aug 2011, 10:34 pm   #12
FERNSEH
FERNSEH's Avatar
I've been working on the TV12 today. The line oscillator failure turned out be be a broken tag on the EF50 valveholder. An easy fix. So it's back to the original line TB fault, lack of width. The 'scope shows that the sawtooth drive is correct: 30volts @ 100microseconds. Note the "sit up" on the flyback part of the waveform. The frame timbase needs some attention.
That's the next stage of the restoration.
DFWB
FERNSEH is offline
Old 23rd Aug 2011, 10:37 pm   #13
FERNSEH
FERNSEH's Avatar
Some pictures. The broken valveholder tag can been seen.
DFWB.
ID:	55448   Click image for larger version
FERNSEH is offline
Old 23rd Aug 2011, 10:52 pm   #14
FERNSEH
FERNSEH's Avatar
The frame timebase turned out to be the same valveholder problem. Two broken tags. The FTB now works in a fashion but the hold control has a dead spot at one end. It's a 2.2Megohms lin pot.
The frame timebase employs a Miller Transitron circuit. The line time oscillator is a more conventional blocking transformer circuit.
Plenty height now but just look at the width.
DFWB.
FERNSEH is offline
Old 24th Aug 2011, 8:17 am   #15
Andy Doz
Andy Doz's Avatar
I think you're inchining into the lead now ....
Does someone have a TV22MKI schematic or trader sheet I can borrow?
Andy Doz is offline
Old 24th Aug 2011, 8:25 am   #16
Cobaltblue
Cobaltblue's Avatar
Try Dukes page here
Enjoy
Mike T
Mike T BVWS member.
www.cossor.co.uk
Cobaltblue is offline
Old 24th Aug 2011, 8:35 am   #17
Andy Doz
Andy Doz's Avatar
Originally Posted by Cobaltblue View Post
Try Dukes page here
Enjoy
Mike T
Unfortunately that's for a TV22A ..
Andy Doz is offline
Old 24th Aug 2011, 10:16 am   #18
HamishBoxer
HamishBoxer's Avatar
Think your Frame Osc Tx could be o/c Andy.
HamishBoxer is offline
Old 24th Aug 2011, 10:17 am   #19
HamishBoxer
Think i have MK1 sheet can scan and send.
Old 24th Aug 2011, 10:24 am   #20
HamishBoxer
Just send me a PM with email address and its sat here on my desktop ready to go!
